Results 1 to 2 of 2
Thread: Ventilation vents
    Aug 2011
    River Heads Q
    4 Post(s)
    Ventilation vents
    I presume wagons are the same but my ute has a bit of a problem.
    When windows are down, one of the vents (picture attached) flaps and makes a very, very, very annoying noise and when windows are up, no noise.
    There is a slotted flap inside that is supposed to let air out when internal pressure is higher and stop dust and water entering when external pressure is higher.
    How do I stop the flapping noise without blocking it off with tape as I have done on the left side to shut it up. Worse that ex wife.UteVent2.jpg
    I have taken outer vent off and it looks right but obviously it is not.
    maybe open it up and see whats lose inside.
