Results 1 to 9 of 9
Thread: Y61 gu patrol converted back to petrol
    Jul 2022
    Have just finished converting patrol TB45E back to petrol, everything seems to work fine the only glitch is the fuel gauges still still read when the ignition is off
    I could not find the sub tank control module,any help would be great
    Jun 2018
    24 Post(s)
    Here you go, here is the sub fuel tank control system document. http://cloud.tapatalk.com/s/62fa1faa311af/subtank.pdf
    Apr 2021
    Brazil
    So it was a ZD30 and you converted it to TB45E?
    461 Post(s)
    I assume it was dual fuel, LPG and Petrol, and he's removed the LPG side of things.
    BrazilianY60 (16th August 2022)
    Apr 2021
    Brazil
    Ah, ok. I wouldn't call that a conversion but ok.
    Jul 2022
    Yes I didn’t explain that real good , I had gas installed on my gu years ago and now decided to change it back to petrol ,so I’ve installed a long range tank and every thing works fine except the fuel gauges still read when the ignition is off
  9. The Following User Says Thank You to Phil58 For This Useful Post:
  10. #7
    Jul 2022
    Thanks Cremulator for that sub tank control link
  11. The Following User Says Thank You to Phil58 For This Useful Post:
    Cremulator (16th August 2022)
  12. #8
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    Quote Originally Posted by Phil58 View Post
    Fuel gauges in my TB45E dash show the correct levels when ignition is off. Always have done.
    John
  13. #9
    Jul 2022
    Thanks John the gas had been on my car for about 12 years forgot how the gauges used to be
