15th August 2022, 10:32 AM
Y61 gu patrol converted back to petrol
Have just finished converting patrol TB45E back to petrol, everything seems to work fine the only glitch is the fuel gauges still still read when the ignition is off
I could not find the sub tank control module,any help would be great
15th August 2022 10:32 AM
15th August 2022, 08:58 PM
Patrol Guru
Here you go, here is the sub fuel tank control system document. http://cloud.tapatalk.com/s/62fa1faa311af/subtank.pdf
15th August 2022, 11:46 PM
Patrol Guru
So it was a ZD30 and you converted it to TB45E?
16th August 2022, 08:04 AM
BrazilianY60
I assume it was dual fuel, LPG and Petrol, and he's removed the LPG side of things.
BrazilianY60 (16th August 2022)
16th August 2022, 12:17 PM
Patrol Guru
Ah, ok. I wouldn't call that a conversion but ok.
16th August 2022, 04:45 PM
Yes I didn’t explain that real good , I had gas installed on my gu years ago and now decided to change it back to petrol ,so I’ve installed a long range tank and every thing works fine except the fuel gauges still read when the ignition is off
The Following User Says Thank You to Phil58 For This Useful Post:
16th August 2022, 08:10 PM
Thanks Cremulator for that sub tank control link
Cremulator (16th August 2022)
17th August 2022, 07:25 AM
#8
Phil58
Fuel gauges in my TB45E dash show the correct levels when ignition is off. Always have done.
John
17th August 2022, 05:39 PM
#9
Thanks John the gas had been on my car for about 12 years forgot how the gauges used to be
