17th August 2022, 09:38 AM
yes the rattle is a feature !
Here in Canberra mine has a rattle most mornings .
Just wait for a bit and away you go .
17th August 2022 09:38 AM
18th August 2022, 11:53 PM
Hi thanks for the replies sorry it has taken so long to answer, I have been away for work. I had 2 glow plugs that were buggered and I replaced them all last night but unfortunately it hasnt fixed the problem. Thanks Brazilian Y60 I will jump.on that link and read what it says now. Also thankyou nissannewby, are u saying that there are 3 different solenoids that I need to check or is it one solenoid that does those 3 things ( coolant temp, injection pulse and timing control ). Thanks again
19th August 2022, 11:04 AM
what part of the Country are you in . I think you maybee chasing a feature not a fault !
My pump was recently rebuilt . startup somtimes sounds like a few spanners loose ... when its -5 C
but soon changes . the control Advances the injection timing up when very cold .
19th August 2022, 03:29 PM
In Tasmania mate, so yes it does cold but it shouldn't do that. I have a couple of other gu utes with td42t engines in them and although I had some trouble with one a few years ago idling rough and blowing lots of smoke on cold starts the problem was fixed when I replaced the dropping resistor that is a replaceable part that goes into the inlet manifold and had pump rebuilt at the same time. The other 2 utes I have are not the td42ti engine so they don't have the few electrics that this one I am having problems with now does, neither of them are intercooled either. Another interesting point is that the other 2 have the dropping resistor in the inlet manifold where the td42ti doesn't!!?? I know at least 4 other people with td42ti engines in their utes and they do not sound like mine does on cold days. It may not cause any problems by making the noise but I want to know what causes it or if in fact it is something mechanical that could lead to a very expensive engine rebuild.
