Results 1 to 5 of 5
Thread: ZD30 will torque converter and plate fit to a manual engine
    Jan 2017
    Hi, Engine in my auto has done 360K and have just sheared the little dowel from timing sprocket driving the cams, so same result as broken timing chain. I can get a manual engine and just do a swap "IF" its possible to swap the flywheel for the existing plate on the back of my existing engine, which is auto.
    Thanks David
    461 Post(s)
    I can't see why not. People are doing auto to manual conversions, vice versa, all the time.
    Dagwill (9th August 2022)
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Maybe someone could check on their Nissan Fast to see if cranks are the same part #.
    I can't see Nissan complicating production by having a different crank for manual or auto when there's no logical reason for it.
    John
  6. The Following User Says Thank You to jff45 For This Useful Post:
  7. #4
    461 Post(s)
    Might be onto something John. But all these part numbers could well supersede to the one part number which this doesn't say.
  8. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Dagwill (9th August 2022), jff45 (10th August 2022)
  9. #5
    Morayfield, QLD
    Cheers, Mark. Looks like the ZDs between 11.2002 & 08.2005 didn't have a crankshaft
    John
