Results 1 to 8 of 8
Thread: Gu drag link replacement?
    Aug 2011
    River Heads Q
    4 Post(s)
    Hi all. Long time since I have asked a question although I have been lurking regularly.
    The rubber bushes/boots at each end of draglink on my son's ute are cracked and need replacing.
    He almost dropped his beer when quoted stupid prices for the whole draglink instead just the rubber boots. As usual Nissan were the dearest but Pedders and Fulcrum were not cheap either.
    A backward step by Nissan from greasable front end on GQ's.
    Has anyone a better option?
    cheers
    330 Post(s)
    No Way i would fit an OEM Drag link Ever mate.
    A Superior or Roadsafe brand Chromoly in 4140 with female tie rod ends for the win. It is the most exposed item on the car for impact and the factory is piss-weak.
    Something like this
    https://www.ebay.com.au/itm/29271921...sAAOSwx3dblNQO
    https://www.ebay.com.au/sch/i.html?_...link&_osacat=0
  4. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    MB (30th July 2022), Wizard52 (30th July 2022)
    175 Post(s)
    As Mudrunner said. Get something decent while you're at it. Anything compared to OEM is stronger. I opted for the superior link. Bees knees.
  6. The Following 4 Users Say Thank You to Hodge For This Useful Post:
    MB (30th July 2022), Rossco (30th July 2022), Stropp (30th July 2022), Wizard52 (30th July 2022)
  7. #4
    Aug 2011
    River Heads Q
    4 Post(s)
    Back again with update.
    Existing drag link is in good condition so does not need to be replaced. It only the cracked rubber boots which will cost $10 from Superior Engineering.
    Pays to shop around.
  8. The Following 2 Users Say Thank You to Wizard52 For This Useful Post:
    MB (2nd August 2022), MudRunnerTD (2nd August 2022)
  9. #5
    Apr 2021
    Brazil
    I have always thought this was the steering link and the drag-link was the wheel to wheel one (or rather, knuckle to knuckle).
  10. #6
    330 Post(s)
    No the link behind the diff from knuckle to knuckle is the Tie Rod (Ties the hubs together?)
    The Drag Link is in front ans goes from the Steering Box to the left side swivel hub and "Drags" the wheels in either direction using the steering wheel and steering box.
  11. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    BrazilianY60 (3rd August 2022)
  12. #7
    330 Post(s)
    Quote Originally Posted by Wizard52 View Post
    Yes indeed. You will get the grease boot for a tie rod end at any Auto shop (Repco, supercheap, autopro) will all sell the. For $10 or so. Nice to have a spare.
    For my money though the first link I changed on both the GQ and the GU was the Drag Link and the Tie Rod as they are both Very exposed and the Drag link is the first thing to hit something. If the tiered end is knackered then don't replace the end, junk the whole thing.
    If he is flat out not using rhe car offroad then go the boot for sure. If he has a head shake replace rhe rod end. If he wants to do some tougher tracks junk it and go chromoly 100%.
  13. #8
    Aug 2011
    River Heads Q
    4 Post(s)
    Cool
    Ute is his work vehicle as a painter (and decorator as I remind him) and we only go fishing to Fraser etc so no rock climbing or mud etc.
  14. The Following 2 Users Say Thank You to Wizard52 For This Useful Post:
    MB (3rd August 2022), MudRunnerTD (3rd August 2022)
