27th July 2022, 12:37 PM
Silly short while testing sensors, please help.
Hi 2004 ZD30 Patrol
I was testing crank pos. sensor at the connection point , top front of engine male plug goes to sensor , female plug goes to engine control??
Tested sensor, ok, then thought I will test supplied voltage etc. at female plug.
Inserted some short bits of wire so it was easy to make contact.
Then in my clumsiness I shorted 12v supply to the signal return, heard a few relays clicking then nothing. No more 12v supply, checked fuses,, what damage might I have done. ???
27th July 2022 12:37 PM
27th July 2022, 02:34 PM
More than likely a fuse or a relay. Thats pretty much all you can do. Fuses are in place for this kind or reason. So if they are all good I would only assume a relay is dead. Most of the Nissan relays can be switched around for another known working one. You just need to find which relay...
27th July 2022, 05:06 PM
Not sure if they're present on the ZDs but have you checked not just fuses but the -fusible links-? Like fuses, but bigger and normally a half dozen of them in a box by one of the batteries/engine bay
Also, parrot clips and skinny and/or sharp multimeter probes prevent this kind of shenannigan
1989 LWB 5-Seat, TD42
28th July 2022, 11:41 AM
I can understand the reason to check fuses ect on the 12v feed.
I am hoping I did not cause damage by supplying 12v to signal wire which i think opperats on 5v, going back to eng. management.
29th July 2022, 04:30 PM
Did some more testing
Tested all fuses with multi meter touching the little bare spots on the back which allows testing without removing the fuses , found with ignition turned on I had 12.4 volts on every one [testing both sides ] EXEPT fuse # 26 listed as start signal 7.5 amps. Removed the fuse and tested bothside where the fuse plugs into. No voltage on either side. ??
anyone knows where its fed from ?
29th July 2022, 05:27 PM
Is there an "edit post" function anywhere,,, is it possible to edit posts.
just found that fuse is only live while cranking
30th July 2022, 11:30 AM
If you look at your post, there will be an "Edit Post" option at the lower right (on a PC at least).
The Following User Says Thank You to Brissieboy For This Useful Post:
