19th July 2022, 10:19 AM
My ongoing clutch line hydraulic problems
1996 GQ, re engined to td42
Replaced clutch flexible hose section with Nissan oem (so it still has the extra top bleed). Was a complete b because of various issues mainly to do with stripped threads, connections done up too tight, and me being a complete amateur
Anyway, cannot get the system bled. I’m suspecting an air leak somewhere. I have re tightened the connections we touched.
Just always getting air out the top bleed. No pressure in clutch.
When we press the clutch I hear an air noise under the bonnet. Is this normal (it could be something to do with the master cyclindernhousing)
Also when you press the clutch I see air bubbles coming up in the reservoir. Is this normal?
19th July 2022 10:19 AM
19th July 2022, 12:30 PM
Clutches are a bitch to bleed sometimes. Open up the nipple on the m/cyl and let it sit for a few hours. Any air will want to go up to the highest point. Then try to bleed the m/cyl alone first, then the next one, then the slave cylinder last.
The Following 2 Users Say Thank You to mudski For This Useful Post:
MB (24th July 2022), mihit (23rd July 2022)
23rd July 2022, 02:06 PM
Air noise is definitely not normal. Could be a borked vacuum booster?
An alternative to mudski's method is to get a decent syringe, vet style, about 250ml, and force the fluid back UP the lines from the slave cylinder end. This will push any crap out the lines into the m/cyl, So i usually will syphon that out, wipe it out.
Take it off and clean it if it's particularly gungy. Then top up to apropriate levels and test as per usual.
- 1990 LWB Safari flatdeck, TD42 -
- 1988 LWB 7-seat Safari, TD42 -
1989 LWB 5-Seat, TD42
The Following User Says Thank You to mihit For This Useful Post:
26th July 2022, 08:39 AM
Patrol Freak
I bought a vacuum bleeder from repco years ago. It sucks the air and fluid through the system. You don't even have to push the pedal. Simple to use and works well.
The Following 2 Users Say Thank You to BillsGU For This Useful Post:
MB (26th July 2022), Stropp (26th July 2022)
26th July 2022, 05:30 PM
