Results 1 to 5 of 5
Thread: My ongoing clutch line hydraulic problems
    Sep 2020
    1996 GQ, re engined to td42
    Replaced clutch flexible hose section with Nissan oem (so it still has the extra top bleed). Was a complete b because of various issues mainly to do with stripped threads, connections done up too tight, and me being a complete amateur
    Anyway, cannot get the system bled. I’m suspecting an air leak somewhere. I have re tightened the connections we touched.
    Just always getting air out the top bleed. No pressure in clutch.
    When we press the clutch I hear an air noise under the bonnet. Is this normal (it could be something to do with the master cyclindernhousing)
    Also when you press the clutch I see air bubbles coming up in the reservoir. Is this normal?
    461 Post(s)
    Clutches are a bitch to bleed sometimes. Open up the nipple on the m/cyl and let it sit for a few hours. Any air will want to go up to the highest point. Then try to bleed the m/cyl alone first, then the next one, then the slave cylinder last.
  4. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MB (24th July 2022), mihit (23rd July 2022)
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Air noise is definitely not normal. Could be a borked vacuum booster?
    An alternative to mudski's method is to get a decent syringe, vet style, about 250ml, and force the fluid back UP the lines from the slave cylinder end. This will push any crap out the lines into the m/cyl, So i usually will syphon that out, wipe it out.
    Take it off and clean it if it's particularly gungy. Then top up to apropriate levels and test as per usual.
    1989 LWB 5-Seat, TD42
  6. The Following User Says Thank You to mihit For This Useful Post:
    MB (24th July 2022)
  7. #4
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    I bought a vacuum bleeder from repco years ago. It sucks the air and fluid through the system. You don't even have to push the pedal. Simple to use and works well.
  8. The Following 2 Users Say Thank You to BillsGU For This Useful Post:
    MB (26th July 2022), Stropp (26th July 2022)
  9. #5
    472 Post(s)
    Bought one of them myself Bill Mate only recently and sat back scratching my head in disgust when it kept pulling in air from somewhere. Gave up and went back to old fashioned ways with Rossco’s assistance pedalling in cab. Found a great Youtubey video later that night that showed how the air was being vacuum pulled through the nipples cracked open threads. The Dudes fix was to very carefully remove the bleed nipple and carefully apply silicone grease I think/hope it was to the middle threads only for a complete seal when vacuum pulling hard longer cracked nipple lines
    Can’t wait to try it again
