Results 1 to 3 of 3
Thread: 03 GU oil light
    Jul 2022
    03 GU oil light
    Hi all I have a 03 GU zd30 I have been led to believe there is a known problem with the oil light staying on
    The fix to it is a new resistor
    Has anyone done this ... Know where the resistor is located
    I would like to do it my self just need to know where the resistor is located
    The master farter
    mudski's Avatar
    465 Post(s)
    The oil light staying on is from two reasons i can think of. Low oil pressure or the sender unit is stuffed. I'd rather fix the issue than putting a band aid on it....
  4. The Following 2 Users Say Thank You to mudski For This Useful Post:
    BrazilianY60 (18th June 2023), Cremulator (14th July 2022)
  5. #3
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    My oil light has been on for a year. I know it's a known issue with the pressure switches with these vehicles.
    The oil is full and it still turns black over 4000-5000kms which shows it's doing it's job so I'm not fussed.
    My dirtbikes have never had oil lights and they still work.
    2008 CRD Auto Wagon
    Factory snorkel, flashlube catchcan pro, 3" manta exhaust, hpd boost controller, dyno-tuned & egr deleted
