Results 21 to 30 of 40
Thread: ARB Hydraulic hi-lift JACK
    474 Post(s)
    Quick Question Mr ARB Bossman
    My compressor is blown up and I have a flat tyre…..any advice from the…..
    474 Post(s)
    Aargh shitbricks, my jackoff doesn’t work either
  4. #23
    194 Post(s)
    Sounds like a typical night in the shed to me.
  5. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (13th July 2022), MudRunnerTD (11th September 2022)
  6. #24
    474 Post(s)
    Wacky thought Philstar, you’ve got an ingenious hydraulic system being built in for F/R Beast winches with Quick Plumbs for auxiliary Farm potential. Why not go the whole way and hydraulic rated ram honestly a Jack to twin-cab GQ tray/bullbar custom mount wherever you like? Suspecting you’d still need a safety prop for each point too in case of fluid blow out/failure and a mechanical jack backup
  7. #25
    194 Post(s)
    Jesus your imagination is fertile. Its all doable I guess. 2" ram at 1500psi=4.7T, 3" ram =4.8T, guess it is worth thinking about, bit of detail design involved, don't know right now. Probably a bit heavier than the ARB unit I would think.
  8. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (15th July 2022), rusty_nail (15th July 2022)
  9. #26
    194 Post(s)
    Placed the order today for the jack, looks a lot safer than the Jackall unit I have used since 1984! Just need to get the base now
  10. #27
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Is there any additional wiring Required with the hydraulic jack Philo or as the name suggests purely hydraulic?
  11. The Following User Says Thank You to Sprock For This Useful Post:
    PeeBee (22nd August 2022)
  12. #28
    194 Post(s)
    Yes I need a 240v supply for the purple dildo I will be using to get the 'up and down' hand action right for the handle. Trust you all had another great weekend?
    Rossco (22nd August 2022)
  14. #29
    Maybe you should just install some outriggers mate? They are hydraulic and don't require 240v
  15. The Following User Says Thank You to rusty_nail For This Useful Post:
  16. #30
    194 Post(s)
    Every bugger makes a noise at how heavy my barge is, yet encourages me to make it heavier! All good ideas but reckon I will leave that one for a bigger barge than mine Nicco. I think the combo between the airbag, ARB jack and Roadsafe jack extensions I should be right. I bought the entire kit so have a couple of safe options on board.
  17. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MudRunnerTD (22nd August 2022), rusty_nail (22nd August 2022)
