Results 1 to 10 of 11
Thread: Roof gutter rust help
    Sep 2020
    GQ long well base station wagon style
    So I have the dreaded rusted gutters. Design flaw in the GQ, the panels there are bent and pressed so at some points there is a sandwich of three overlapping plates and the seam rusts from the inside out.
    anyway
    ive cut out the rust. yes it was 100 times worse inside than out. Yes it may eventually come back in the future further down the gutter, but this will give us a few more years. Will weld new sections in. This is a new project for us, never done welding and patching, but hey I will just give it a crack and see how it goes. Worst comes to worse I get a real fabricator in to fix my stuff ups.
    see photos. Yes the previous owner had simply bogged a few holes without doing anything more
    The issue is rust prevention on the inside.
    questions
    1
    i will want to rust proof the inside of the patches . I will use gal primer spray on the inside of the patches before assembly. Weld area will however need more on the inside (the bald spray will burn away - and even weld through would need more treatment). Then I’m thinking of drilling through from the inside of the cab through the liner and inner sheet, then spray primer and then fish oil on the inside of the patches. The liner seems glued around the edge. Not really removable. Any tricks there? Just drill a hole then put a clip through the hole (I’ve got a box of assorted car trim clips)?
    2
    I’ve made the patches. I’m pretty please with the fit considering this is my first time ever. Just took my time and got a nice fit. I’ve hit a problem. how to make the gutter. I tried to bend the metal patch to make a new gutter, but it dint have the equipment to accurate tight bends like that. So I made a flat patch and then to weld a new gutter onto the patch. Buggered if I can do it though. The patch isn’t straight (I’ve made to flow similar to car original lines, which isn’t dead straight. Do I even need a new gutter? Is it just for roof racks?
    3
    strength. The original sheet there is sometimes three sheets together. Would a single patch be OK. Would it matter if it isn’t? The gutter section is quite low and just above the bottom join. The three sheet section is above the gutter.
    thanks for any tips.
  2. The Following 3 Users Say Thank You to MartyS For This Useful Post:
    MB (10th July 2022), mudnut (10th July 2022), Rossco (10th July 2022)
    192 Post(s)
    Hey mate, yep had the dreaded gutter rust on my GQ, decided to go a shell swap with a clean one, big job but she came up good. . . Only regret (probably few others lol) was not pulling the head lining out to treat inside properly. . Reckon this is the only way to get in there with ease to apply some sort of product and know you've got the best coverage possible. . However the applicators for treating inside of chassis inserted through little hole might be a good option in theory too but guess won't know till you try it. . Headlining is glued around windows and pillars so bit of a gamble if it can be resurrected once unstuck, not sure on price and availability but would imagine new one should be available. .
    As for gutters have seen people remove them on ute's and look pretty good so could do the same I'm sure with wagon but yep would loose ability to fit rack. . If you could source a wreck cutting bits of gutter out to patch in would work you world think. . Anyways good luck sure she'll come up great
  5. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    MartyS (12th July 2022), MB (10th July 2022)
  6. #3
    472 Post(s)
    G’day @MartyS Mate!
    Could be worthwhile creating a ‘Wanted’ to good home type thread certainly on here and elsewhere too seeking the rear GQ gutters you require.
    There is a lot of GQ twin cab custom ute chops happening out there these days and they generally throw the wagon backs away or scrap metal them.
    Best of Luck Mate
  7. The Following 2 Users Say Thank You to MB For This Useful Post:
    MartyS (12th July 2022), Rossco (10th July 2022)
  8. #4
    194 Post(s)
    Reckon I know someone with one willing to hel. Where are you located @MartyS? Also do a search on here for now are, he has done a malor repair on his roof gutters, full of great ideas. He is located in NZ from memory nhoward is the search topic
  9. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    MB (10th July 2022), MudRunnerTD (10th July 2022), Rossco (10th July 2022)
  10. #5
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Link here:
    http://www.nissanpatrol.com.au/forum...f-rust-repairs
    @OP... you sure have your work cut out (hah) for ya.
    1989 LWB 5-Seat, TD42
  11. The Following 3 Users Say Thank You to mihit For This Useful Post:
    MB (12th July 2022), PeeBee (11th July 2022), Rossco (11th July 2022)
  12. #6
    Sep 2020
    Brisbane
    Manly west
  13. The Following 2 Users Say Thank You to MartyS For This Useful Post:
    MB (12th July 2022), PeeBee (12th July 2022)
  14. #7
    194 Post(s)
    OK, got something in Melb, sure you could pick up something closer!
  15. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (12th July 2022)
  16. #8
    472 Post(s)
    Maybe post down the rear cut outs, as templates, we’ll see what can be agriculturally found
  17. #9
    472 Post(s)
    EDIT: Cardboard/Baking Paper cheap postage letter meant
  18. #10
    194 Post(s)
    I reckon we could trim out a chunk bigger than necessary and then he trims to suit. Packing would require a wooden box of some sort to preserve the shape based on my AustPost or TNT experiences.
  19. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (12th July 2022)
