Results 1 to 10 of 14
Thread: Genuine Disc brake pads ? GU
    May 2016
    8 Post(s)
    Hi all what's peoples thaughts on Genuine Disc brake pads . the original ones need to be replaced soon 250,000 kms .
  2. The Following User Says Thank You to Tip12345 For This Useful Post:
    MB (21st June 2022)
    465 Post(s)
    I've used Genuine pads for a long time now. No issues at all. Im almost due for a new set and will buy them again without doubt.
  5. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MB (21st June 2022), Tip12345 (20th June 2022)
  6. #3
    193 Post(s)
    Yeah another vote for genuine, find they stop heaps better than Bendix and wear isn't too bad really. .
  7. The Following 2 Users Say Thank You to Rossco For This Useful Post:
  8. #4
    174 Post(s)
    The genuine ones on mine were more effective than wishful thinking, but only just. Their level of performance was 'dangerous'.
  9. The Following 4 Users Say Thank You to Cuppa For This Useful Post:
    BrazilianY60 (20th June 2022), jff45 (20th June 2022), MB (18th June 2022), Tip12345 (20th June 2022)
  10. #5
    473 Post(s)
    I know zero about brakes but wondering if your big DX Leafy Ute Beast towing across our Great Land on your Top Adventures @Cuppa Mate does require better than OEM? I know my old work DX leafy was a pig of a thing to pull up around town with heavy trailers and seem to recall you kindly mentioning something about “Green Pads” or similar are better for hauling Patrols ?
  11. The Following User Says Thank You to MB For This Useful Post:
  12. #6
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    I’m running the RDA/EBC all round with Yellowstuff pads, I rate the combination highly. Followed the bedding in instructions to the letter.
    In my opinion way better than the genuine and that's with a fair bit of towing involved.
    Jack
  13. The Following 2 Users Say Thank You to jack For This Useful Post:
    MB (20th June 2022), Tip12345 (20th June 2022)
  14. #7
    174 Post(s)
    The point at which i determined they were dangerous was long before we had loaded up for travelling & were not towing. I driving home at moderate speed to whar was our new home near Ballarat. Uncertain ogf the turn off I needed to take I saw it fairly late. In any other car I could have slowed & made the turn without difficulty, but the with my foot jammed hard on the brakes I still overshot it!. Yes I went to EBC Greenstuff pads with RDA dimpled & slotted rotors - a huge improvement. Now on the yellowstuff pads - same but better on long descents as they can handle heat better (not that I had a problem with the green stuff pads, but the higher heat tolerance for me is a peace of mind thing). However there are now other options - the hydraulic booster arrangement someone here recently fitted arrangement sounds really good, although for now I'm happy to stick with what I have.
  15. The Following 2 Users Say Thank You to Cuppa For This Useful Post:
    jff45 (20th June 2022), MB (20th June 2022)
  16. #8
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    The hydro boost has made me fall in love with my Patrol all over again especially teamed up with slotted rotors and ECB pads.
    Slowly getting used to the pedal having almost zero travel. It’s like it starts to brake when it senses your foot just touching it.
    Absolutely love it!
    John
  17. The Following 5 Users Say Thank You to jff45 For This Useful Post:
    Cremulator (20th June 2022), geoffayres (30th July 2022), jack (20th June 2022), MB (20th June 2022), Rossco (20th June 2022)
  18. #9
    473 Post(s)
    Quote Originally Posted by Tip12345 View Post
    Not exactly sure Tip Mate
    On A Budget Too, can anyone helpfully suggest?
  19. #10
    Morayfield, QLD
    With the genuine pads, the 4.8 pads are claimed to be the better choice.
    John
  20. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    geoffayres (30th July 2022), MB (22nd June 2022)
