15th November 2022, 03:14 PM
#21
15th November 2022 03:14 PM
20th November 2022, 06:52 AM
#22
First trip since making the upgrades went well.
Just a hours drive out to where we have some cattle on agistment near Bendigo.
Boost seems to be topping out a little lower at 12PSI down from 13-14 and EGT topped out around 250c while engine temps were nice and low as expected considering how cold the weather was.
Fuel use is looking to be good so far which was the main reason for the lift pump to fix fuel use going from ~12l to ~20l after a tank of fuel on a new fuel filter.
Need to see if waste gate adjustment can get the boost closer to 15PSI or if it just needs the fuel screw on the pump wound out which is currently at the lowest setting.
The Following 4 Users Say Thank You to Dasa For This Useful Post:
BrazilianY60 (20th November 2022), MB (20th November 2022), MB TD42 (3rd December 2022), Rossco (20th November 2022)
