Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: 94 GQ Coil Cab
    Advanced Dasa's Avatar
    Aug 2019
    North central VIC
    94 GQ Coil Cab
    Pulled the bull bar off this morning and only snapped half the bolts in the process.
    The UHF antenna even came off easier than expected thanks to rats having chewed it's cable in half behind the battery.
    Plan is to replace the DTS air box with a Radius air box when it arrives and install the FMI & oil catch can, along with trying to direct more air through the rad while I'm in there.
    Not sure the old rust bucket is worth it but at this stage it's all good fun.
  2. The Following 5 Users Say Thank You to Dasa For This Useful Post:
    AB (3rd June 2022), MB (5th June 2022), mihit (1st October 2022), mudnut (3rd June 2022), Rossco (3rd June 2022)
    581 Post(s)
    Yep bloody rats!
    They ate Rosscos heater lines, MB's brake fluid cap and they even ate my bread maker machine haha
  5. The Following 2 Users Say Thank You to AB For This Useful Post:
  6. #3
    192 Post(s)
    Yep bloody rats!
    Bwaha yep farkers could have ended bad damitt. .
  7. The Following User Says Thank You to Rossco For This Useful Post:
    MB (1st October 2022)
  8. #4
    109 Post(s)
    Yep bloody rats!
    You bastard.......
    Sorry Dasa, long story.
  9. The Following 2 Users Say Thank You to Plasnart For This Useful Post:
    AB (4th June 2022), Rossco (4th June 2022)
  10. #5
    Aug 2019
    North central VIC
    Been a while but a little progress has been made.
    Moved the alternator wiring and the vacuum hose but still needs a bit more work to make sure it is secure and wont rub a hole.
    Lost a little gas when changing the angle of the AC fitting at the front and it seems I have gotten away with bending the pipes by hand to move the AC dryer to the side a bit.
    Shortened the rad hose a little so that it clears the hot side intercooler pipe.
    Hot side Intercooler piping is about done but still a bit to go on the cold side.
    Trimmed a bit off the battery box corner and will probably buy a bit shorter belt for the power steering.
  11. The Following 6 Users Say Thank You to Dasa For This Useful Post:
    Bidja (15th November 2022), BrazilianY60 (7th October 2022), MB (10th September 2022), mihit (1st October 2022), mudnut (6th October 2022), Touses (12th September 2022)
  12. #6
    Aug 2019
    North central VIC
    Mate just dropped off the manifold inlet for me he had welded together after hacking up the old DTS inlet.
    Still need to trim a bit more out from the grill and find some mesh to cover it up without affecting airflow to much I hope.
  13. The Following 3 Users Say Thank You to Dasa For This Useful Post:
    Bidja (15th November 2022), MB (7th October 2022), mudnut (6th October 2022)
  14. #7
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Watching with interest. Nice job.
    I'm planning to "slap a turbo on" one or three of mine. I was going to go for top-mount intercooler, just from a space and airflow perspective (winch, bars, grille etc) but always interested to see what people come up with...
    1989 LWB 5-Seat, TD42
  15. The Following User Says Thank You to mihit For This Useful Post:
  16. #8
    Aug 2019
    North central VIC
    Finished of the intercooler mounts.
    Picked up two 45 to finish the last stretch of pipping into the manifold but it was too close to the power steering so I used a 90 that was left from the original DTS intake but it looks to need a little trimmed off so that it is not pushing into the battery, tomorrows job.
    The 90s above the manifold do touch the liner but I am not sure how hard they pres against it, should probably look into that.
  17. The Following 4 Users Say Thank You to Dasa For This Useful Post:
    BrazilianY60 (7th October 2022), MB (7th October 2022), mudnut (6th October 2022), Touses (7th October 2022)
  18. #9
    472 Post(s)
    Looking Great Dasa Mate
    Wondering/imagining/possibly your real corrugations home area roads your IC might appreciate some vibration shielding Brother
    Rubber washer (homemade) either side of your L bracket retained by a washer top and bottom and maybe a longer stud required to allow 2 x nuts underneath to lock off without over compression of the rubber anti-vibe homemade goodies
  19. The Following 2 Users Say Thank You to MB For This Useful Post:
    Cremulator (8th October 2022), Rossco (8th October 2022)
  20. #10
    472 Post(s)
    Same same just noticed too on the top of your beautiful New IC Brother
    Never ceases to amaze nuffy me what corrugations in your top neck of Australia can do to lighter beautiful metals
  21. The Following User Says Thank You to MB For This Useful Post:
