Results 1 to 5 of 5
Thread: Glow Plugs?
    Patrol Freak
    May 2016
    lower west victoria
    30 Post(s)
    Glow Plugs?
    2013 GU CRD.
    Getting harder to start on cold mornings. I usually have to give it 2 blasts of the glow plugs before she'll start. 195,000ks, original glow plugs. I hear the relay click when off when the dash light goes off.
    What is the resistance I should I see when measuring the resistance with the plugs in place? I read 0.5 ohms, is that correct?
    I've also read that the steel tipped glow plugs can cause issues if you don't perform a 'timer mod' is that still the case?
    I've also read that there are carbon and steel tipped plugs, which of these are better? I was going to get OEM plugs.
    Thanks for any help.
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    If the ones you have now worked for nearly 200,000 km why would you want anything different?
  4. The Following User Says Thank You to BillsGU For This Useful Post:
    10G (6th June 2022)
  5. #3
    Patrol Freak
    May 2016
    lower west victoria
    30 Post(s)
    Quote Originally Posted by BillsGU View Post
    Yep, good point Bill.
  6. #4
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    Also check the fuel lines around the fuel filter, that can contribute to a hard start, some of mine got hard and cracked. If you replace them use "nitrile rubber" type.
    You can test your plugs by cleaning them, putting them back in, doing a cold start, pull them out and replace the ones that are covered in soot.
    2008 CRD Auto Wagon
    Factory snorkel, flashlube catchcan pro, 3" manta exhaust, hpd boost controller, dyno-tuned & egr deleted
  7. The Following 2 Users Say Thank You to pollenface For This Useful Post:
    10G (6th June 2022), mihit (6th June 2022)
  8. #5
    Patrol Freak
    May 2016
    lower west victoria
    30 Post(s)
    Quote Originally Posted by pollenface View Post
    Thanks mate, I'll check those hoses out.
