Results 1 to 10 of 10
Thread: New member
    May 2022
    New member
    Hey guys, I’m an 89 TD42 SWB owner hoping to find some dash wiring information! My speedometer and temp gauge cut in and out so with any luck here I can find the information I need. Cheers all
  2. The Following User Says Thank You to Mmmmud For This Useful Post:
    MB (31st May 2022)
    Feb 2011
    Shed
    45 Post(s)
    G’day mate welcome aboard
  5. #3
    581 Post(s)
    Welcome to the forum mate!
  6. #4
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
  7. #5
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    Welcome to the forum.
  8. #6
    May 2022
    Thanks everyone! It’s been parked up in the shed for a good 6 months or so as I’ve been busy with work and other bits in life. Took it out to get a warrant last Friday and on the way home that’s when my gauges started glitching! Doesn’t seem to be much wiring info out on the web!
  9. #7
    SW Vic.
    80 Post(s)
    Quote Originally Posted by Mmmmud View Post
    Check the fuse and panel for any signs of heat, loose contacts or corrosion. If all good and the fault affects more than one gauge, it will most likely be a fault in the loom connector behind the cluster, or a loose earth to the cluster. You might have to clean the contact points where it meets the flexible plastic circuit board.
  10. #8
    May 2022
    Cheers for the reply. Have checked fuses and panel everything seems to be okay.. pulled plug out of the back of dash and gave a good clean, still no luck. Only seems to be speedo and temp gauge affected.. Have been trying to find a wiring diagram to track down the dash earth, how do I get access to downloads on the forum?
  11. #9
    May 2022
    The weird thing is that is i tried fixing it a month or so ago, pulled the cluster out. Chucked a voltmeter on the power wire for speedo and it suddenly had power. Speedo and temp gauge started working, put cluster back in went and got my warrant and on the way home speedo and temp gauge stopped working again.. which makes me wonder if it is a loose connection/contact on the cluster or plug
  12. #10
    SW Vic.
    80 Post(s)
    Sounds like you are getting close to the problem. If you have clicked on the links to download the manuals and its not working, try talking to a forum moderator.
