Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: td42 conversion tacho doesnt work
    Jul 2018
    Pre sure I figured out the calibration counts the dimples/holes on the camshaft gear being I BELIEVE 6 dimples/holes depending on ti or non to motor.
    Yeah doesn't blink until over 1k revs. My sensor doesn't output 1v ac until over 1k revs I'm going to assume that just means that my sensor is a touch dodgy but it seems to be fine when it's above 1k revs.
    If I run the diagnostics on the Dakota it just reads 0 input until it hits 1000 then reads it's at what I believe to he accurate.
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    12 Post(s)
    You said it was a silvertop so it shouldn't have the dimpled Ti cam gear.. unless someone swapped it over for some reason. See if you can borrow another tacho pickup just to compare.
    John
  4. #13
    Morayfield, QLD
    12 Post(s)
    Otherwise, you might just have to learn to live with it. I never watch my tacho at idle anyway..
    John
  5. #14
    Jul 2018
    Nah it's definitely a gq motor/gear l.
    Yeah looks like that might be the case.
    Just don't understand the reason behind not getting 1v at idle but so many others are.
    Appreciate your help none the less.
  6. The Following User Says Thank You to Dousa For This Useful Post:
    jff45 (19th May 2022)
