Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 89 GQ Flat Tray Rear Diff
    Oct 2010
    Old Bar, NSW
    Not sure where the idea that a leaf diff has coil mounts as that is not correct, they are totally different.
    These diffs are a bit bigger than a coil from what I understand the GVM is greater with leaves. They also have drum brakes.
    The coil diff has disc brakes.
    What you need to know is if it fits in the mounting points in a GQ, if the drive shaft is going to fit and the ratio is the same as you took out.
    They are supposed to be the strongest diff available, a couple of guys in our club have tough trucks and these are the diff of choice in that competition.
    Good luck mate
    Macca
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by zeimi View Post
    Glad there no such thing as stupid questions lol. Just looking at the pics of the 06 GU diff, it says leaf sprung and I can see the leafs in the pic, so just out of curiosity does that still mean that the diff would have coil mounts? (and yes I know, I should ask the seller, but again I like asking questions)
    No the mounts would be totally different and the leaf mounts would have to be removed and coil mounts welded in place. The only a silly question is the unasked one mate
  4. #13
    Jul 2011
    Sweet I'm starting to understand this a bit so Macca the explanation of the differences between leaf and coil was cool, leaf gives you more weight capacity for loads so thats why the utes have them and say the 4 door wagon GQ patrol is coil. And now I also understand why the axle out of a coil sprung diff is no good to my leaf sprung diff, it's to short (and ratio of diff may be different so guessing could have more or less teeth on drive end. One thing I'm getting confused about though Growler79 if my GQ already has leaf sprung diff and I'm just replacing with leaf sprung diff I shouldn't have to worry about coils right, cause you either have leaf or coil. (lol I don't think I've used the word leaf this much ever )
  5. #14
    Feb 2011
    Shed
    45 Post(s)
    Correct mate a leaf sprung diff from a GQ ute should bolt straight upto your GQ ute
  6. #15
    Benarkin QLD
    Quote Originally Posted by growlers71gq View Post
    Thats right
    OP,Save the brain strain on yourself
    Get the part/parts that are correct to the car
    leaf spring diff, get a leaf spring diff
    As i mentioned they are around and cheapish as minimal demand
    Now IF your a touch "Green" on the subject youll have endless trouble swapping stuff from other models
    Diff ratios are different , depending on motor, model , ect
    Throw a wanted add in the classifieds on this , and perhaps other forums
    Youll find what your chasin
  7. #16
    Jul 2011
    Yep spot on MQ MAD, I put up a few wanted ads for a 1 for 1 if I get what I've already got less for me to stuff up
