Results 1 to 3 of 3
Thread: transfer case
    Advanced
    Oct 2020
    2 Post(s)
    transfer case
    Hello to all,poopsie here again,the transfer case shifter shifts fine when moving it back to 4high,it goes into 4low when pushed down and moved rearwards,when I try to get it back to two wheel drive the shifter will not pop up and I have to pull it up quite hard to get it into the 2wd position and cause the green 4wd light to go out.Makes me think a spring is broken.
    Thanks for any feedback.
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    Sounds like there is dirt and crud around the shifter at the TF case. Maybe clean around it, pop off the rubber boot and apply a bit of grease.
  4. The Following User Says Thank You to mudnut For This Useful Post:
    growler2058 (10th May 2022)
  5. #3
    Advanced
    Oct 2020
    2 Post(s)
    thankyou sir,the boot was cracked and had dirt in it,sprayed lanotec in it ,works heaps better now.I was a bit worried the ls3 had stuffed the transfer box,thanks again.
