20th April 2022, 03:09 PM
obd port
Where is the OBD port on a 4.2 l y60 petrol. Cant find it anywhere. Had to replace injectors and now need to adjust idle.
20th April 2022 03:09 PM
21st May 2022, 09:40 PM
Assuming it’s and efi….. all Nissans around that era only have a Nissan consult connector. It should be located under your steering wheel near the fuse box. However I’d say it’s more than likely your IAC valve on the way out or your pedal cable is adjusted wrong
