Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Failed RE4 after upgrades.
  1. #21
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    Ideal operating temp is generally considered to be around 80C but with low stall TCs and/or TC lockup, the temp being pumped out by the TC is often lower.
    Mine can get down to 65-70 pre cooler on the highway.
    I’ve thought about getting the fluid direction controlled by thermostat so it only goes through the cooler over 80C but I haven’t got around to it.
    They were telling me it will run hotter with the low stall in it? I thought it would be cooler as well due to not as much slip? I think 80° is ideal temp in the pan?
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    Quote Originally Posted by stevemc181 View Post
    You should be running above your stall speed on the highway so I'd expect it to run cooler because of that. I use the stock J6 TC which stalls around 1950-2100 and with 3.9 diffs it doesn't often get over that at cruising speeds.
    I run at 1850 rpm @ 100 km/h with TC locked and trans temps coming out of the box just plummet.
    I run a big Davies Craig cooler in series with the factory TB45E cooler which, btw, is about half the size of the stock ZD30 cooler so my trans temps are always too low unless I'm towing the caravan.
    I've had my trans temp gauge hit 120C on one occasion but that doesn't worry me as it's pre cooler temps and I run full synthetic fluid. It drops quickly when I get the chance to hit the TC lockup button.
    The factory trans temp warning light comes on at 140C but most agree that that's already too hot for mineral fluid and clutch damage has already started.
    John
  4. #23
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    @jff45 Thanks for the info. I’ll keep a close eye on the temps for this trip and see how she goes. I’ve got about 10’000km to cover, in a variety of highway/desert terrain.
    When I get back I’ll have a look and see if I can shoehorn this in https://www.tuffcarparts.com.au/aero...ansmission-oil
    I’ll also change the fluid out to synthetic as they used a Dex3 mineral fluid in it.
  5. #24
    Morayfield, QLD
    13 Post(s)
    You can always manage trans temps with the manual TC lockup. Just engage it when not under load and avoid loading it once locked. You'll see the temps drop quickly.
    There are those who are happy to keep their TC manually locked during shifts but I avoid it as does the factory behaviour.
    Castrol TransmaxZ is considered the best trans fluid but it costs. I use Nulon multi-vehicle synthetic. The important thing is that they flush the whole trans with it, about 12 lts, not just the 4.5 lts in the pan.
    John
  6. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    MB (26th April 2022), stevemc181 (26th April 2022)
