Results 1 to 7 of 7
Thread: Td42 brake calipers
    Sep 2014
    Td42 brake calipers
    Hey guys, does anyone know why there has to be lower guide pin equipped with rubber sleeve? At least it is in a single piston calipers. Only answer I found was in the Patrol4x4 forum. It was "it is for toit own safety" . I think it is just an intersting way to say that "I do not know but I like to shine out".
    Sep 2014
    The car is a GQ from 1995
    194 Post(s)
    I thought there was a rubber sleeve on top and bottom pins - more to hold the lubricating grease in than anything - maybe I am wrong, recall two on the twin pot calipers. Without the protective rubber sleeve the pins jam up with corrosion.
    mudski (29th March 2022)
    Sep 2014
    I believe you are talking about the ribbed rubber boots that cover the part of the pin that is sticking out from the calipers and is visible when assambled and installed. I how ever am talking about the rubber sleeve what is pulled over the hidden end of the lower pin. It looks like a piece of hose pulled on the pin, lower only. And I can not explain to myself why it is needed there. Note, it is not the first car I am doing the brake overhaul. Others did not have it.
  7. The Following User Says Thank You to Ilvesekesekene For This Useful Post:
    PeeBee (30th March 2022)
  8. #5
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    I know the sleeve you are talking about, seen a few different cars with them, why they have them ....my guess would be to stop the pin from rattling
  9. The Following User Says Thank You to garett For This Useful Post:
  10. #6
    Sep 2014
    That was my best guess also but was just wondering If there was something else.So basically if I replace the pin with the rubber with a pin without on the worse thing that can happen is a rattling brake calipers.
  11. #7
    Jan 2015
    19 Post(s)
    Quote Originally Posted by Ilvesekesekene View Post
    it may wear out quicker... I have seen a few without the rubber sleeve that should of had one ... also seen them swell do to the wrong stuff being used to grease or clean them.
