Results 1 to 10 of 10
Thread: Brake grease?
    May 2016
    lower west victoria
    30 Post(s)
    Brake grease?
    What type of grease do I need to grease the slide pins etc in the brakes? Will any silicon grease do??????
    Thanks.
    Bendix ceramasil or equivalent.
  4. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    10G (9th May 2022), santik (25th May 2022)
    May 2016
    lower west victoria
    30 Post(s)
    Thanks Craig.
    465 Post(s)
    I used a waterproof grease when I did mine. Morey's Truck and Farm I used. Its what I use on everything. Good shizz.
    Interesting. Does it not react with the rubber components over time?
    465 Post(s)
    No it hasn’t which is good. Well from last inspection which was a while ago
    Expert Arfa Brayne's Avatar
    Jul 2016
    Have use moly grease in the slide pins for years (cv joint grease). Doesn't seem to bother the rubber pin seals
    Tried silicone grease once and they gummed up before the next oil change - silicone grease turns to water as soon as it gets warm. A bit of spit could do a better job.
    "Can't" is a dirty 4 letter word.
    Best way to deal with a "Can't" is to chop off the "t" and brew it in boiled water for a few minutes.
    Sip on the "t", and consider what you've got left to work with
  10. The Following User Says Thank You to Arfa Brayne For This Useful Post:
    MB (9th May 2022)
  11. #8
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    With my recent caliper overhaul job I used a tube of Bosch rubber grease. You can put it on everything brake related even on the seals and pistons.
    John
  12. #9
    May 2016
    lower west victoria
    30 Post(s)
    Thanks everyone for the info, much appreciated.
  13. #10
    May 2022
    I think Bendix ceramasil is also the best.
    I have my own astrology blog. In my blog, you can find info about zodiac signs compatibility, and personality.
