Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: death wobble
    But how good are the wiper blades?
    Sent from my XQ-AT52 using Tapatalk
    They are Mint!!!
    Apr 2021
    Brazil
    Quote Originally Posted by timbo2410 View Post
    I have had an off centre bearing installed in mine
    I have never heard of such a thing... are you sure about it?
  4. #13
    Yes there is. I ran this offset top kingpin bearing on the passenger side of my GUIV for many years and it sorted out tyre scrub, drift and wobble for a long time. I rate rhis mod.
    http://safetsteer.com.au/portal/content/view/192/338/
  5. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    BrazilianY60 (11th May 2022), growler2058 (11th May 2022), Touses (11th May 2022)
  6. #14
    May 2016
    8 Post(s)
    check the adjustment of the wheel bearings .. My ute with 50mm lift is mostly stock ..
    BFG tyres . air bags on the Back .. tighten up the wheel bearings . A bit tighter and was a bit worried . But it fixed it .. So .
  7. #15
    473 Post(s)
    Harmonic’s, much like bridge collapse’s occur, poor or lied to maintenance of all parts millimeter accentuating IMHO
  8. The Following 2 Users Say Thank You to MB For This Useful Post:
    Hodge (14th May 2022), taslucas (14th May 2022)
  9. #16
    175 Post(s)
    MR MB here kindly nailed it. Even a micro disturbance can send the whole lot out of rhythm, and harmony is broken.
    Mine is perfect now across the whole speed range (knock on my empty nogging it stays so) . I chased my wobble gremlin for months with a heavy machine gun shooting $$$ bullets at it...
    During that time it used to drive like a dream at all speeds. Then i'll drive over a tiny bump, even those reflective doodahs on the freeways, and then whole thing will start dancing and won't go away until i was at very low speeds.
    In the end new bearings fixed mine, but only temporary. After that it was the draglink and panhard bushes and been good ever since.
  10. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    Cremulator (14th May 2022), Rossco (14th May 2022)
