6th April 2022, 09:05 PM
geoffayres
Upgrade the turbo and fit a performance pump.....and clutch....
No more hill problems...
...otherwise, convert your auto hubs to manual, or fit manual hubs from a ute or DX wagon.
… or convert it to auto trans
John
The Following User Says Thank You to jff45 For This Useful Post:
geoffayres (6th April 2022)
6th April 2022 09:05 PM
7th April 2022, 08:08 PM
Moderator
If you are going to be doing this a lot then I'd be considering changing diff ratios to be honest.
Short answer is Yes but all the reasons above re the hubs is true.
If you have a Factory TD42T them you will be running 3.9:1 Diff ratios. Your car will be a far better tow pig running some 4.1:1 will make a difference for sure.
Check out my Toy -->
Rogue Dung Beetle
7th April 2022, 08:10 PM
Moderator
Changing different ratios will also lift your cruising rpm up a couple of 100revs and your TD will thank you.
Your TD42T HATES 2000rpm. Don't cruise at 2000rpm. Do you have a EGT Guage? If you don't you should fit as a matter of urgency.
Rogue Dung Beetle
8th April 2022, 01:56 PM
You will only get transmission wind up if you travel in 4WD on hard surfaces AND turn corners. When you turn corners your front and rear wheels travel different distances and that is where you get lock up. If you take off from lights in a straight line there is no problem - just remember to change to 2WD as soon as you can.
27th April 2022, 08:43 PM
Breadmaker Shaker
Williamsheikspare
Its a great idea to go for hill riding, And nissan has a powerful engine can bear such hilly roads
Oi Billy Wigglestick, you don't need 25 posts for the manuals. Stop posting shit.
