Results 1 to 10 of 15
Thread: fuel filter change
    Expert jman69's Avatar
    S.A.
    fuel filter change
    Hi there, juust wondering if when i replace my fuel fliter can i pre fill it with diesel before screwing it back on?
    primihg is such a hassle.
    465 Post(s)
    Of course you can. Not sure why priming is a hassle though. Not like its hard to do. Takes a whole 20-30 pumps and its done.
    jman69 (13th March 2022)
    174 Post(s)
    To make priming much quicker & much easier fit a 'bulb primer' (diesel compatible) in the fuel line before the filter. Have had one on mine for must be 7 or 8 years now.
    eg. https://www.ebay.com.au/itm/31372598...8AAOSw8rNhd5lr
  6. The Following 4 Users Say Thank You to Cuppa For This Useful Post:
    clawrence (21st March 2022), growler2058 (22nd March 2022), MB (13th March 2022), mudnut (13th March 2022)
  7. #4
    S.A.
    Rito thanks fellas. And thanks cuppa rekon i'll get one of those bulb primers.
  8. #5
    473 Post(s)
    Please do take note of Cuppa Mates advice: “before the OEM filter” much like an electrical lift pump would push forward also.
    Recently experienced trackside attempting to palm (bulb) pump through/after an OEM filter/primer and they do appear to counteract each other sucking the palm bulb flat/shut.
  9. #6
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    I always fill it up as much as I can.
    When you disconnect the hose between the pump and the filter keep it high with a zip tie as to not let any fuel drip out to minimize the chance of air bubbles.
    Pump it until it overflows then connect it all back together.
    2008 CRD Auto Wagon
  10. #7
    S.A.
    Thanks M B,pollenface. Good advice, i"ll keep it all in mind for the next change.
  11. #8
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    if I have trouble priming the fuel I push it up with an air compressor in the filler neck ...
  12. #9
    Apr 2021
    Brazil
    That is probably hard to "seal" the filler opening to the compressed air hose isn't it?
  13. #10
    Jan 2015
    19 Post(s)
    stuffing a rag around the air gun is enough to push it to the filter, it is nice to have another person to help,
    you don't want to go over board with the pressure.
