Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: GQ TD42 vac pump Alternator recommendations?
    Apr 2015
    Got a silvertop GQ td42 with vac pump on alt in a GU4
    my auto8 alternator doesn't give any voltage until 1300 rpm
    my original Hitachi one died and it used to charge at idle once I excited it
    and revved it a little bit to wake it up but it too struggled with lights on,
    demister and ac on
    I'm looking at replacement alternators to buy and alot of the reviews
    are saying the same thing ( crap voltage at idle )
    What is with all the crappy alternators that don't charge at idle
    or can't hold 14v with the AC fans and lights on?
    Can anyone recommend a alternator brand that will charge at idle
    192 Post(s)
    Hey mate can confirm that mine is the same once she's had a good glow and the starters turned over lights on dash will just flicker . . Charges good once up and running but yeah not ideal. . Can you still get the Hitchi unit, other than that can't be much help sorry but keen also to find out. .
    sunshinecoast
    the problem may not be the altenator . i have a zd myself ( vac pump separate from alt ) but have read discussions on the older models . it seems people upgrade the +ve power wire from alt to battery and the -ve from bat to engine to stop voltage loss . also there are a couple of wires that come plug into the alt . a solid white one and a white with red stripe . i think if i remember correctly the white with red stripe goes to instruments and the white goes to the power wire that goes from the alt to the battery but joins into the wire not far from the alt . both of these wires have had know common problems with breaks and dodge connections at the connector into the back of the alt . the connection and/or breaks need to be fixed in the white with red stripe wire . the solid white wire needs to be replaced and run all the way to the battery +ve terminal so that it will read the voltage properly so the alt will put out enough voltage . these wires don't need to be larger as one dosen't carry much load and the other is only a sensor wire .
    Apr 2015
    Going to try source a 66m alternator pulley like this one
    https://store.alternatorparts.com/pa...ternators.aspx
    just having a hard time finding someone to ship it to australia
    also going to do diode trick to see if this will help aswell
    Nov 2021
    i had to go through this not so long ago,
    i was in a rush for one i ended up buying a jaylec 80a with vac pump on the back from patrol apart.
    Then i ran into the issue that it doesnt charge while idle witch is a pain when your in traffic and its raining, heater on, demister on ect the wiper motor is so slow haha
    Apr 2015
    Ordered a UFI Alternator kit comes with a bosch 160amp alternator and some bits and bobs for the bracket spacer plug, will keep updates when it arrives
  8. The Following User Says Thank You to Bozanceroz For This Useful Post:
    MudRunnerTD (5th August 2022)
    Quote Originally Posted by Bozanceroz View Post
    160amps!!!! I want one of those!!! Have you got a link please
  10. #8
    Apr 2015
    I've spoke to Matthew from UFI about it check ur PM
  11. #9
    Apr 2015
    going to be ordering a vacuum gauge tester tool and seeing how much vacuum i pull at idle and at 1000rpm and 2000-3000 rpm
    then im going to be installing a hella up28 vacuum pump off a ve/vf commodore with a gq vacuum canister setup and test the vacuum again
    ill be doing this after my trip hopefully
  12. #10
    472 Post(s)
    FWIW: Scored an insane 180A aftermarket built GQTD (yes with vac) off an Ebay Legend years ago. Was only advertising for a short time out there but Crikey did the 6hp High Mount (12v :-( haul hard for 1 maybe 2 trips.
    Them Diodey thingies in the back as @PeeBee once kindly tought me also need to be upgraded to handle the pimped well above the back ends capabilities
