Results 1 to 10 of 12
Thread: Check engine light
    Patrol God Stropp's Avatar
    31 Post(s)
    Check engine light
    Ok so coming home the trusty td started to make a slight mechanical rattling then the check engine light came on, checked everything and it was fine about 2k down the road it did the same thing, I’m at a loss as there is no smoke or anything, I did clean the air cleaner as it was fairly filthy but no change, it seems to happen when I get the intermittent rattly sound it’s fine until that happens. I have it booked in on Tuesday to scan it and find out hopefully what it is.
    201 Post(s)
    Wouldn't have a clue sorry Stropp, how was the oil pressure looking?
    Keep us updated.
    Stropp (27th February 2022)
    49 Post(s)
    Dodgy sensor maybe..
  6. The Following User Says Thank You to jay see For This Useful Post:
  7. #4
    581 Post(s)
    Yep like Winnie said, oil pressure ok?
    Stupid question but oil level ok?
  8. The Following User Says Thank You to AB For This Useful Post:
  9. #5
    31 Post(s)
    Don’t have a pressure gauge but it runs quiet then after about 1km it makes a slight chattering rattle the light comes on and then the rattle goes and comes again 🤷*♂️🤷*♂️
  10. #6
    It will be something to do with the tcv on the injector pump. So could be the tps, the sensor on #1 injector or the timing control valve solenoid in the bottom of the injector pump. The rattle will likely be the engine as when this light is on it is likely the pump has gone to full advance which makes engine rattle more.
  11. The Following 4 Users Say Thank You to nissannewby For This Useful Post:
    04OFF (2nd March 2022), MudRunnerTD (28th February 2022), pollenface (2nd March 2022), Stropp (28th February 2022)
  12. #7
    31 Post(s)
    Thanks mate, it’s going in tomorrow to get the scanner on to see and hopefully fixed, it’s got a 12mm ufi pump
  13. #8
    31 Post(s)
    1251F7FF-842D-49BF-B45F-7B58D7B9CC4E.jpegWell possibly found the problem, light no longer comes on but I think I may need to drop the tanks and I’ll check the filter again in a week or two or if the light comes on again, it’s really odd like white strips, maybe debris from the last refuel .
  14. The Following 3 Users Say Thank You to Stropp For This Useful Post:
    mudnut (1st March 2022), mudski (1st March 2022), Rossco (1st March 2022)
  15. #9
    31 Post(s)
    Ok so further checks we have tightened the contacts on the tcv and then discovered the alternator isn’t charging so that’s possibly upsetting the tcv as well so now it’s a 130amp alternator
  16. The Following User Says Thank You to Stropp For This Useful Post:
    mudski (3rd March 2022)
  17. #10
    Dodgy operator I reckon
  18. The Following 2 Users Say Thank You to Avo For This Useful Post:
    04OFF (2nd March 2022), Stropp (3rd March 2022)
