8th March 2022, 05:01 AM
Creaky steering.
Hi guys.
I'm getting a creaking sound when I'm turning my steering wheel. It's coming from inside the cabin so I know it's not the box or the outside steering components. I have a leak coming from the top of the windshield over the driver's side and I believe that water has gotten into the steering inside. What can I do to stop the noise?
1989 Nissan Patrol DX with the td42 (inline pump). No mods yet except black US 16x8 rims with 265 75 16 Ats
8th March 2022 05:01 AM
8th March 2022, 08:54 AM
I had a similar creak on my clutch pedal, just use some grease, or of it's too hard to apply in that space, some oil using a tin oil can with a thumb pump.
The Following User Says Thank You to Cremulator For This Useful Post:
Lawrence (10th March 2022)
8th March 2022, 05:35 PM
Wd40 specialist spray on lithium grease bunnings! 😀
The Following User Says Thank You to Mickhead For This Useful Post:
10th March 2022, 04:18 AM
Where on the steering wheel would I apply the grease/WD40?
10th March 2022, 02:01 PM
The way I located it on my clutch pedal was to put my head in the footwell area and press the pedal with my hand. If you can do the same and turn the steering wheel, you might hear/see where the contact point is - I would guess on the steering column?
I just used some WD40 to start with which removed the squeaking on my pedal but it didn't last long, so applied grease.
Lawrence (12th March 2022)
