12th June 2012, 06:38 PM
#41
Thanks MQ, do appreciate your advice, I'd be up that creek smelling like a dunny otherwise lol
Whoever disagrees with the saying "Might is right" obviously doesn't own a MQ
12th June 2012 06:38 PM
12th June 2012, 09:57 PM
#42
The ruond bulb from your MQ is called a "Sealed Beam" Headlight. The MK one is a " H4 Halogen BulB" Headlight.
These both types come in round and "square" headlights in all the common sizes.
Tim
13th June 2012, 04:59 AM
#43
Thanks for that Tim, I'm intending to retain the MKs head lights when I do the body swap as don't want to stuff around making mods to fit the round headlight. I'm assuming that all I'd have to do is change the bulb over from 24 to 12.
13th June 2012, 09:19 PM
#44
aussiemale
correct you are
16th October 2013, 10:53 AM
#45
Will the mq front quarter panels fit on the mk. I know the mk has the extra supports running from the window forward does that stop the mq panels fitting?
17th October 2013, 04:39 AM
#46
Mk has rubber bushing for springs (as well as different type springs), while mq had steel greasable bushings. I had to change mine (87 ute) out to the steel ones as one of the front springs had broken on mine and dealer ordered the mq springs. They have different amount of springs according to the spec rather than the year i think, My ute had 3 springs per pack at the front, whereas i have seen a deluxe wagon with around 6 springs per front spring.
1989 Nissan Patrol DX with the td42 (inline pump). No mods yet except black US 16x8 rims with 265 75 16 Ats
23rd October 2013, 08:57 AM
#47
Combination switch has different plug
mk
mq
Reason: add pic
7th October 2014, 12:00 AM
#48
I have a 4spd mk l28 it was the last 4spd built before the switch too 5spds. Only about 4 months between the last 4spd and a 5spd upgrade on the mk, can get a little confusing.
12th March 2015, 12:41 PM
#49
look like a great project. Very informative stuff bud! Thanks wasnt sure which model i had.
17th December 2018, 11:05 PM
#50
perfect thread, i bought my patrol in a hurry and only now seem to know its model number.thanks
