Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: MQ /MK differences
    Benarkin QLD
    MQ /MK differences
    Thought id start this to help those a bit new on the scene
    Ill keep adding as differences are found, or add your own if you know any
    Headlights
    MQ - Roundheadlight
    MK - Rectangle headlight
    Grills
    MQ - Round headlight
    Taillights/Lenses
    From top to bottom
    MQ
    Indicator-Amber
    Brake-Red
    Reverse-Clear
    MK
    Brake-Red
    Brake-Red
    Reverse-Clear
    (With a seperate indicator in the rear bumper)
    Steering wheel
    MQ
    2 Spoke
    MK
    3 Spoke
    Although some povo pack/MK utes have the MQ style 2 spoke wheels
    Radio pod
    MQ
    Flat removable , top of dash mounted radio pod,with a small compartment beside radio
    MK
    Tapered removable , top of dash mounted radio pod with a clock on the passenger side of radio
    Motor
    MQ SD33 N/A
    24 Volt diesel with factory left and right engine bay mounted battery trays
    MK SD33 N/A and TURBO
    12 Volt diesel battery mounted on passenger side of engine bay
    Thatll do for tease
    More later
    Jul 2010
    Waterford West Qld
    wheel arch flares are fiberglass except Luxury model MK which had steel wheel arch flares.
    Luxury MK had suspenion ride seats.
    Benarkin QLD
    There was only the steel flares from factory,on the Deluxe version
    Glass flares are aftermarket
    There are the "Wide wheel pack" Fibreglass flares, these bolt threw the side of the guards
    MQ/MK Stone tray/valance tray
    (Bit under grill)
    MQ
    4 Symetric holes between indicators,same size as indicator lense holes
    MK
    6 Symetric slots (3 lots of 2) between indicators,different size as indicator holes
    MQ /MK
    Inner guard supports
    MQ
    Dont have any extra bracing behind front guards
    MK
    Do have extra bracing behind front guards
    (This bracing goes from under the windscreen pillar and runs the length of the inner guard ,in a forward direction
  5. The Following User Says Thank You to MQ MAD For This Useful Post:
    Finly Owner (6th August 2011)
    Front shackle bolts were larger diameter on MK
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    i think one of them has straight shackles and one has stepped out ones (wider on the top, narrower on the spring).....if that makes sense? Is this right MQMAD?
    Hello from Under Down Under!
    Campbelltown NSW
    MQ straight shackles
    MK stepped shackles
  9. The Following User Says Thank You to pod For This Useful Post:
    taslucas (6th February 2012)
  10. #7
    Advanced jc58nc's Avatar
    May 2011
    Batemans Bay NSW
    MK petrol can have a 5 speed box from the factory.
    MQ petrol 4 speed only.
  11. #8
    Benarkin QLD
    Quote Originally Posted by jc58nc View Post
    MQ all engine combos are 4 speed in manual configeration
  12. #9
    Advanced Johan Safari's Avatar
    Cockatoo VIC
    Transfer cases are different between L28/P40/SD33.
    Tail shafts are different depending whether LWB/SWB/type of transfer
    Diff ratios anybody?
  13. #10
    Benarkin QLD
    Quote Originally Posted by Johan Safari View Post
    Gearbox bellhousings are different between these as well
    Input gearbox shafts are different as well
    Starters are different
    Diff ratios are different between MQ/MK,but interchangeable except the H260 ute diffs, which the centres arent interchangeable as the H260 diffs are huge and mainly found in utes
    But complete diff housings will be fine for the swap
    Ratios,from memory
    P40 4.11
    SD 33/L28 MQ 4.6
    SD33T MK 4.33
    Ute 4.88
    There are other options in the diff ratios but not offered in aussie versions
