22nd February 2022, 04:32 PM
tb42e problem
Is there a way to clear the ecu on a 1992 Y60 TB42e? will any OBD work with it? I removed the gas stuff some time ago but it has been a problem since. It will cut out at 2k revs even when its warm but if I leave it stand about an hour it will start and run as normal. I have had the Maff unit replaced and the mechanic has suggested a new dizzy as all else seems ok. I'm a little averse to this as it was running ok before I removed the gas and its leeches and now back as nature intended it except for this problem. Any ideas fellas?
Pete
22nd February 2022 04:32 PM
6th May 2022, 08:25 PM
To clear TB42E ecu, remove battery terminals, and put the terminals together to discharge any current left in the system.
"Can't" is a dirty 4 letter word.
Best way to deal with a "Can't" is to chop off the "t" and brew it in boiled water for a few minutes.
Sip on the "t", and consider what you've got left to work with
The Following User Says Thank You to Arfa Brayne For This Useful Post:
