20th February 2022, 11:48 AM
Snow control /AT control kicking in by its self
Hi Guys
I have a 2004 4.8L Patrol, Y61.
My patrol has an AT /snow control that keeps coming on intermittently..... Only when slowing down under 10km or at a complete stop....
The car takes off in 3rd or 4th and lacks power until it comes up to match the speed of the gear it takes off in...If I turn the car off, the computer resets and the problem goes away until another unexpected time...
I have had the wiring harness checked but nothing obvious was found by the auto electrician... I have changed out the AT controller relay. Diagnostics done by a transmission specialist resulted in the replacement of 2 solenoids and the auto trans oil. There were no issues with the transmission.
The costs are starting to mount up and even Nissan are at a loss to find the cause. Other forums show that it has happened before with other 4.8s & no one has found a solution.
Does anyone have any ideas or experience with a similar issue?
Scotty
20th February 2022 11:48 AM
20th February 2022, 12:58 PM
SUCH IS LIFE
Weird one, have you tried disconnecting the battery overnight to clear the ecu?
Only other thing I can think of is to reflash the tcu or ecu
________________________
______ 2017 D-Max _______
The Following User Says Thank You to Maxhead For This Useful Post:
growler2058 (20th February 2022)
20th February 2022, 02:24 PM
Hi yes ... iv tried disconnecting the battery ... for 24 hours... it reset everything, but hasn't fixed the problem...
The Following User Says Thank You to backhome007@hotmail.com For This Useful Post:
