Results 1 to 5 of 5
Thread: TB42 Head Bolt Torque and Sequence Cheat Sheet
    Advanced LandRoverGhost's Avatar
    Jun 2016
    Warrumbungle
    In my search for the correct Torque and fastening Sequence of the head bolts I ended up in a 'jungle' of snippets of info all over the web.
    So I created this all-in-one cheat sheet.
    The data comes from a head bolt supplier.
    I added a graphic showing the final torque angle of 74 degrees. Cut it out and paste to a piece of cardboard or metal.
    Redesigned it all in an easy format.
    In jpg or download the PDF:
    Nissan Patrol GQ TB42 Headbolt Torque sequence J .pdf
  2. The Following 6 Users Say Thank You to LandRoverGhost For This Useful Post:
    Cremulator (13th February 2022), Cuppa (13th February 2022), MB (7th May 2022), mudnut (13th February 2022), PeeBee (12th February 2022), Pete49 (7th May 2022)
    174 Post(s)
    Stuff like this would be useful to save somewhere on the forum for future users to find easily. Is that possible?
    LandRoverGhost - good on you, you have been making some useful posts recently.
  5. The Following User Says Thank You to Cuppa For This Useful Post:
    MB (7th May 2022)
  6. #3
    Maybe start a Sticky Thread: TD42 facts, figures and helpful hints. Like I did for the RB30.
  7. The Following User Says Thank You to mudnut For This Useful Post:
    MB (7th May 2022)
  8. #4
    Expert Arfa Brayne's Avatar
    Jul 2016
    Good to clean out the threads in the block with a thread tap if you've got one. Surprising how cruddy they get.
    Remember to make sure there is nothing (grease. oil, crud, gasket debris) in the bottom of the head bolt thread holes.
    Then lube up the head bolts and washers with a bit of gear oil before fitting.
    Re-torque (one at a time) after a few thousand k's when you adjust the tappets.
    "Can't" is a dirty 4 letter word.
    Best way to deal with a "Can't" is to chop off the "t" and brew it in boiled water for a few minutes.
    Sip on the "t", and consider what you've got left to work with
  9. The Following 2 Users Say Thank You to Arfa Brayne For This Useful Post:
    LandRoverGhost (7th May 2022), MB (7th May 2022)
  10. #5
    Jun 2016
    Warrumbungle
    Certainly important - I used an old head bolt , grinded flat a bit on one side.
  11. The Following 2 Users Say Thank You to LandRoverGhost For This Useful Post:
    Arfa Brayne (8th May 2022), MB (7th May 2022)
