12th January 2022, 08:39 PM
Where can I source a clip like this?
This clip is in the throttle arm of the Standyne Injector pump. It holds the end of the accelerator cable from falling off. Is it a fuel injection repairer type of fitting or is there a kit or store that might sell these? I have a couple from Brunswick Diesel, however its the sort of thing that can stop you if it comes loose, or like it did for me, decide to ping off under the hood and took a good hour to find.Clip 1.jpgClip 2.jpg
12th January 2022 08:39 PM
12th January 2022, 09:29 PM
12th January 2022, 09:56 PM
MB
In situ pictures pretty please Philstar, Chev Intrigued too Old Mate
Maybe not the clearest context photo but it is the retainer on the end of the throttle linkage arm on the injector pump. I think there is a better one in my build, will have a look
12th January 2022, 09:58 PM
If possible, drill a small hole in the arm and modify a washer and cotter pin. Gotta be safer than that clip.
The Following User Says Thank You to mudnut For This Useful Post:
PeeBee (12th January 2022)
12th January 2022, 10:14 PM
Post #62 of my build, found this photo of a dirty old unloved draft horse, but looks like it may have a different clip holding the accelerator cable adapter onto the shaft.
http://www.nissanpatrol.com.au/forum...ser-6500/page7
12th January 2022, 10:15 PM
mudnut
I might do that Craig, more direct, but knowing me I will screw it up and it will become a 3K repair!
13th January 2022, 12:14 AM
When it's installed cover it with silicone. It should never come off then unless you want it to.
The Following 2 Users Say Thank You to nissannewby For This Useful Post:
mudnut (13th January 2022), PeeBee (13th January 2022)
13th January 2022, 10:07 AM
#8
He's smarter than the average bear!
13th January 2022, 10:20 AM
#9
Try Speedscreen now called Control Connections, in Campbellfield Phil. They do all this sort of stuff.
https://controlconnections.com.au/
13th January 2022, 10:28 AM
#10
mudski
Thanks Mark, dropped them a line with the photos, will report the feedback.
Phil
mudski (13th January 2022)
