17th December 2021, 08:59 AM
Drop Pipe Broken 2014 GU
Its been quite some time since I last posted but am in urgent need on advice to replace my drop pipe, Snapped off?? As I have options to eliminate the entire exhaust system my priority right now is to get through xmas and the budgets lookin thin. I have read posts last night that make me feel that a 3 inch drop pipe done correctly could be a quick fix, I may just cut my losses and go the entire system. Pending availability of labour this close to xmas.
Its a daily drive so time is important right now
Therefore a couple of quick questions if I may please.
1. Can anyone recommend a fitter around Dandenong who are good at Patrol 3.0l crd fit ups?.
2. There are so many to choose from, Any feedback on your setup would be appreciated.
3. If I go just the drop pipe only, I am aware I need the correct flange to match the rest which I could do myself ( remaining system install). Im wanting to travel Aus next year and will have more $$ once my current personal situation ends. What other things should I consider now (on just the drop pipe) for future upgrades if i just go the drop pipe before this purchase?
4. Could I just get it welded up, trying to attatch pic but not working..
Ive read up a bit over the years but not up to scratch with the current market as its growing and as normal cheaper systems with respect are not my choice.
Ps: hope this all makes sense as i am at work and limited in my time to post this.
Lifes a journey not a destination.
17th December 2021 08:59 AM
17th December 2021, 01:54 PM
The dump pipe should be bolted to the motor towards the bottom of the pipe to stop it from breaking. I would remove the whole pipe and weld it up if you were trying to save money.
