15th December 2021, 06:47 PM
Starting / running problems .. which scan tool for 2000 Gu Y61 ZD3 DI Patrol
Hi all, I’ve had a quick look at existing posts and can’t find what I need to know (but I’m blonde)
I’m the go between for my housemate who is not computer savvy, so pls bear with me if I am not asking the right questions
Garry is looking to find out which scan tool, diagnostic reader or whatever you call them nowadays, to try and find out why he is having problems with starting his Patrol. He replaced the ignition relay (with a second hand one borrowed from a friend) and it did start, but then faltered. He is trying to find out which scan tool to buy.
Have been told OBDII by some people, but others say they are for 2007 upwards. ECUtalk has been mentioned.
The plug under the dash shows 16 pins, but it may possibly only use 14 of those. It’s a tapered plug that needs to be plugged in.
He is at a complete loss at this stage. Any help would be greatly appreciated. He doesn’t want to buy one of these things to find it doesn’t work, as they cannot be returned.
If anyone can think of why this is happening, their thoughts would also be welcome
Cheers and beers
Jenn
15th December 2021 06:47 PM
16th December 2021, 07:40 AM
Missing in Action
Codes can be extracted & cleared manually. Hope this helps.
MANUAL EXTRACTION
1. Switch ignition ON.
2. Confirm the Check Engine Lamp illuminates.
1. (The system will be in Diagnostic Test Mode I.)
2. Bridge Diagnostic Connector terminals 1 and 8.
3. Confirm the Check Engine Lamp extinguishes.
4. Wait at least two seconds.
5. Disconnect the bridge between Diagnostic Connector terminals 1 and 8.
6. (The system will be in Diagnostic Test Mode II.)
7. Read Fault Codes as flashes of the Check Engine Lamp.
Read the codes by counting the number of flashes of the Check Engine warning lamp. The
code numbers are displayed as sets separated by a 2.1 second pause. Each set comprises
a series of 0.6 second flashes, a 0.9 second pause and a further series of 0.3 second
flashes. The first set represents the first 2 digits of the code and the second set
represents the last 2 digits.
Example 1 - Code 0102 (Air Flow sensor) would be shown as one 0.6 second flash, a 0.9
second pause and two 0.3 second flashes.
Example 2 - Code 1004 (Injection Pump fuel cut out system) would be shown as ten 0.6
second flashes, a 0.9 second pause and four 0.3 second flashes.
Note: To cease retrieving codes or to read codes again, turn the ignition off and wait at
least ten seconds before restarting the above procedure if necessary.
CLEARING FAULT CODES
1. After reading the fault codes as described, reconnect the wire bridging terminals 8 (IGN)
and 1 (CHK) while the ignition is still on.
2. Wait at least two seconds and then remove the wire bridging the terminals. Any stored
codes should now be erased.
Note: Fault codes are also erased if the battery is disconnected for more than 24 hours.
3.Road test the vehicle and check that there are no fault codes stored.
FAULT CODE TABLE
0102
Mass Air Flow Sensor Circuit, Sensor or ECM failure
0103
Engine Coolant Temperature Sensor(excessively high or low voltage at ECM)
0104
Vehicle Speed Sensor(signal not sent when vehicle is in motion)
0203
Accelerator Position Switch (incorrect signal sent to ECM)
Accelerator Position Switch fault or ECM failure
0208
Overheating Fault
Cooling Fan system failure, Engine coolant re-filling procedure not followed,
Cooling system faulty, Engine lubrication problem
0301
ECM 2, failure (calculation function is malfunctioning)
Internal IC failure
0402
Fuel Temperature Sensor(incorrect signal for fuel temperature received)
Refer to Injection Pump Control Unit. Circuit, Sensor or ECM failure
0403
Accelerator Position Sensor (out of range signal received from sensor or switch assembly)
Circuit malfunction, Accelerator Position Sensor failure,
Accelerator Pedal Dual Contact Position Switch failure, ECM failure
0406
INT/AIR volume (excessively high signal from Mass Air Flow Sensor)
Air Duct, Charge Air cooler, Variable Nozzle Turbo Charger Control System,
Variable Nozzle Turbo Charger, Mass Air Flow Sensor failure, Circuit malfunction
0407
Crankshaft Position Sensor Circuit, Sensor or ECM failure
0502
Battery voltage (excessively high voltage sent to battery)
Incorrect jump starting, Battery, Alternator, ECM
0504
Automatic Transmission Communication Line
(ECM receives incorrect voltage from Transmission ECM)
Circuit malfunction, Automatic Transmission ECM
0505
No faults detected
Monitored circuits are operating normally
0701
Camshaft Position Sensor
(incorrect signal from the Injection Pump Control Unit)
Circuit malfunction, Injection Pump Control Unit
0702
Top Dead Centre Pulse Signal
0703
Pump Communication Line
0704
Spill Valve Circuit
0705
Pump Control Module
Circuit malfunction, Injection Pump Control Unit failure
0706
Spill Valve
Circuit malfunction, Spill Valve, Injection Pump Control Unit
0707
Fuel Injection Timing Control System
Circuit malfunction, Injection Pump Control Unit failure, Poor fuel quality
0802
Barometric Pressure Sensor (built into the ECM)
Internal circuit malfunction, ECM failure
0804
ECM internal input signal processing function malfunctioning
ECM failure
0807
Brake Light Switch
Circuit malfunction, Switch failure
0901
ECM Failure (calculation function is malfunctioning)
Internal IC failure
0902
ECM Relay (incorrect voltage received by the ECM from the relay)
Main Relay malfunction, Circuit malfunction
0903
ECM Internal input signal processing function malfunctioning
ECM failure
0905
Turbo Pressure
Circuit malfunction, Charge Air Pressure Sensor failure
1003
EGR Volume Control Valve
Circuit malfunction, EGR Volume Control Valve failure
1004
Fuel Cut System
Circuit malfunction, Injection Pump Control Unit failure, ECM failure
1401
to 1408 Nissan Anti Theft System
Refer to Anti Theft system information
The Following 2 Users Say Thank You to VK2FMIA For This Useful Post:
Fruitloop (16th December 2021), Touses (16th December 2021)
16th December 2021, 04:52 PM
Hi Fruitloop
Any OBD2 scanner WILL NOT WORK! I have 2002 Gu3 zd3 and the socket looks like an obd one. Apparently some earlier ones were square. An OBD device fits mine but will not connect. Ever.
I have a bluetooth device called NISBIE plugged in here and bluetoothy connected to an android head unit. No IOS support here. It is glitchy, but it works. It does not cost much either. You download NDSI software to the android device, pair it with the Nisbie and it will tell you what errors are present. And let you clear them.
But.. your mate is struggling to start his car, is it throwing a Check Engine Light? If not, the diagnostic device will not help you.
Cheers!
Ps starts and falters? Fuel filter?
The Following User Says Thank You to Mickhead For This Useful Post:
16th December 2021, 05:42 PM
Faaaaaaaaarrr .. out. I read this out to him, and HE just told me the ‘check engine light’ comes on all the time (has been for years)
He said he has been turning the key on and off a couple of times and it goes away 🤷*♀️ I didn’t know any of this 🤦*♀️
He redid the head etc ? a month or so ago, and it was fine, then suddenly didn’t want to start, or if it did, wouldn’t drive for long before it decided to park up. He has changed the fuel filter, but made no difference.
I’m seriously think I’m gonna have no hair left by the end of this 😶
Cheers & Beers
16th December 2021, 05:44 PM
Thanks for all that, but which diagnostic tool ?
From the second reply, I dont think anything is gonna help him atm 🤦*♀️
