Results 1 to 8 of 8
Thread: Low Boost & whislting
Hybrid View
    Advanced Mcflurry's Avatar
    Dec 2018
    Hi all,
    I'm trying to track down a boost leak on my '09 GU but having very little luck. I have a dawes + needle valve and have replaced all the hoses, removed the intercooler piping pre and post intercooler and found nothing. I've tried spraying the intake piping with soapy water and revving but found no bubbles. Turbo to manifold bolts are tights... and I don't have access to a compressor.
    Any ideas what I can try next?
    Brad
    2009 GU
    581 Post(s)
    I'm sure you've done this but have you had a good inspection of the intercooler for any little cracks, etc?
  3. The Following User Says Thank You to AB For This Useful Post:
    Mcflurry (8th December 2021)
    Dec 2018
    I had a go and didn't see anything obvious, a few small leaks on the intercooler but this change in performance was very sudden. I'm not sure whether an intercooler leak of this size would form so suddenly.. unless this has happened in the past?
    2009 GU
    462 Post(s)
    Quote Originally Posted by Mcflurry View Post
    Replace or repair the IC first I think then reassess. Other than this the exhaust manifold has possible warped or cracked.
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    Check your turbo pipes are tight on the turbo. Had this one a while back, similar symptoms.
    Hard to track at idle. Only manifests at revs, was a lucky guess on mine.
  8. The Following User Says Thank You to Touses For This Useful Post:
  9. #6
    581 Post(s)
    Not sure mate, unless the crack has suddenly gotten bigger somewhere.
    That was just my first guess as I remember when our work car 3L had a crack on the IC. The performance wasn't that overly down but you could really hear the turbo whistle coming out of the crack on the IC though.
    Almost like the IC amplified the sound.
    Would be good if you could somehow bypass the IC for a quick test.
  10. The Following User Says Thank You to AB For This Useful Post:
  11. #7
    Advanced Lionel84's Avatar
    Feb 2013
    Brisbane, QLD
    I had a boost pressure line that wasn't tight from the intercooler to the boost pressure sender. The sender barb was thinner than the hose and let high pressure air out. It was whistling like a blower, and after I put a zip tie on it, I got back 2psi of boost.
    2007 Nissan Patrol Y61 Wagon AT 2009 ZD30CRD Engine
    Snorkel, Tillex, HPD Intercooler, 3" King Brown Exhaust, 2" Bilstein Lift, Steel Bar and 12000lb Winch, Engine Bay Lighting
  12. The Following User Says Thank You to Lionel84 For This Useful Post:
  13. #8
    Dec 2018
    Thanks for all the messages guys, I read on here someone had an issue with their Dawes valve which caused this and sure enough... I pulled it out, gave it a clean and we're back!
    2009 GU
  14. The Following 4 Users Say Thank You to Mcflurry For This Useful Post:
    AB (8th December 2021), mudski (8th December 2021), Stropp (9th December 2021), Touses (8th December 2021)
