Results 1 to 5 of 5
Thread: Tb42 EFI runs likes hairy goat
    Sep 2020
    Hello everyone, my tb42 efi idles good but as soon as you rev it up a bit it will start crackling and backfiring through exhaust . Has been retimed multiple times and is set to about 12 degrees BTDC . My tachometer also dances all over the place when revved I have changed CAS,MAF and both plugs going to them. Is there a reason behind this also has new ecu/injectors/fuel pump/plugs/leads/coil
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    The most common causes:
    Sep 2020
    Those thing have been checked if not replaced. Tachometer sits at 4 grand when revved slightly. engine light also flashes.
    Cheers,Bailey
    SW Vic.
    80 Post(s)
    So you have used vacuum gauge to test the inlet manifold? There is a thread dealing with the readings different conditions cause on a vacuum gauge, but I can't seem to find it.
    I think it is an electrical problem anyway. A loose wire or bad connector.
  6. #5
    Sep 2020
    Thanks for the help.
    Problem has been found. I removed the dizzy and pulled it apart and scuffed back the steel disc that slides into CAS it had a little bit of corrosion on it which must have been giving sensor bad reading.put it all back together and runs a treat.
  7. The Following 2 Users Say Thank You to PatrolOwner69 For This Useful Post:
    mudnut (15th December 2021), Stropp (17th December 2021)
