Results 21 to 30 of 35
Thread: Penrite 15w-50 in a TD ?
  1. #21
    Ballarat, Vic
    161 Post(s)
    Just out of curiosity , do you use the Penrite engine flush prior to oil dumps ?
    They gave me a bottle of it. I've never used a flush before. I tipped a tiny bit in.
    Didn't know it existed. I just ensure the motor is well warmed up before dumping the oil.
    2006 4.2TDi ex-Telstra Remote area Camper. 425w roof mounted solar, 360Ah Aux batts, BCDC1240, Onboard hot & cold pressurised & filtered water, (25 litre hot water calorifier), ARB fridge, ARB freezer, Built in kitchen, heaps of easy access storage, 240v, 3” Genie exhaust + dynotune, 2” lift, 3900kg GVM upgrade, second glovebox, ROH Blaktrak steel wheels, Bridgestone D697's (now Toyo RT's), Redarc gauges/pillarpod, Hema HX-1, Icom 450 CB, dual rear view cameras, Onboard 30amp Victron mains charger, second glovebox, dual seat conversion, Tyredog TPMS, Boss PX7 onboard air with 9 litre tank, 350w inverter, Steel bullbar, Harrop Eaton diff lock (front), Warn winch, Snorkel, Dual spares , 160 litre water tank, 180 litre fuel in two tanks (approx 1200km range) 2010 Tvan Tanami. (incl another 70 litre water tank) with matching wheels/tyres (& 3rd spare)
  2. The Following User Says Thank You to Cuppa For This Useful Post:
    MB (7th December 2021)
    Ballarat, Vic
    161 Post(s)
    my one hasn't lost a drip between services. She's only 160k yung though.
    So far the Tee Dee is smooth and dandy with a free drop of penrites Aussie own 15 50 , and purring along nicely.
    Hope to maybe be a convert from here on in, like @Cuppa .
    Mine now has 240k & also doesn't lose any oil between changes.
  5. The Following User Says Thank You to Cuppa For This Useful Post:
  6. #23
    195 Post(s)
    Does anybody actually measure the oil they drop? I don't, so can't say how much I use in between changes, but it stays roughly at the same point on the dipstick.
  7. The Following User Says Thank You to Winnie For This Useful Post:
  8. #24
    Ballarat, Vic
    161 Post(s)
    Yep thats what I do.
  9. The Following User Says Thank You to Cuppa For This Useful Post:
  10. #25
    162 Post(s)
    Yep the dipstick is the only way. I check weekly ...
    Sent using Pixel 6
  11. The Following User Says Thank You to Hodge For This Useful Post:
  12. #26
    416 Post(s)
    Out of Honest interest Chrisso Mate, same same adventure we all had, which oil are you running these days Legend, You & Your Beast were unstoppable FULL Credit Track Leader
    Winnie (7th December 2021)
  14. #27
    195 Post(s)
    I have always used Caltex Delo 400 but it is no longer available, switched to Castrol Rx 15W40. Only used it this one time so far, just checked now and has definitely used a bit, estimating around 5mm on dipstick in 3900km.
    The cold tinnies and warm fire were calling mate, would have taken too long to get to camp if we all got stuck!
  15. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    Hodge (8th December 2021), MB (7th December 2021)
  16. #28
    416 Post(s)
    Never Honestly meant that Brother, BEST UHF Advice I’ve Personally Ever Heard Legend
    A Perfect Scenario, Roll on into Camp with Shiploads of Logs Ready 🪵
  17. The Following User Says Thank You to MB For This Useful Post:
    Winnie (8th December 2021)
  18. #29
    162 Post(s)
    That's what I've used for years till they canned it.
    Think I've personally depleted the last 2 drums found in Melbourne last year.
    Sent using Pixel 6
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    21 Post(s)
    I'm also using the Penrite 15/50 semi synth.
    I've found if I'm Miss Daisying, short runs to and from work etc, it will chew thru a bit.
    The moment I load the backpack or start dragging the camper trailer that pretty much ceases.
    The big whooer loves to work.
  20. The Following 2 Users Say Thank You to Touses For This Useful Post:
    Hodge (10th December 2021), MB (11th December 2021)
