Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: TD42ti bad knocking on warm up
    Aug 2020
    Mackay
    I'd get a second opinion on the timing... Most places will advance it too far to get peek performance when the engine is at running temp but can create a bad knock when cold. Is not good for your engine if that's what it is.
  2. The Following User Says Thank You to Buster3696 For This Useful Post:
    mudski (26th November 2021)
    Patrol God Stropp's Avatar
    20 Post(s)
    Quote Originally Posted by Buster3696 View Post
    Yes I took mine to Jindabyne and I thought the next morning that I had wrecked the motor however when I got back down it quieten didnít down, I have a 18g turbo and 12 mm boosted pump so itís been advanced a lot.
    2003 gu3 td42tdi roaming this great country
  5. #13
    162 Post(s)
    Have you tried different oil?
    I've experimented with many different oils and brands over the years and it amazes me how the engine sounds and "feels" under different lubes.
  6. The Following User Says Thank You to Hodge For This Useful Post:
    Stropp (29th November 2021)
  7. #14
    410 Post(s)
    Any chance @Mitch_11 Mate you could kindly post up an audio or Youtubey file when time permits?
    Plenty of helpful people out there/hear/here that may be able to confirm the Top Injector Pump Potential issue learnt too
  8. #15
    May 2016
    8 Post(s)
    its the internsl pump adjustment nothing user servicable . Its part of the pump set up
