31st October 2021, 03:34 PM
Oil from front freewheel hub on GQ
I am getting traces of oil on the outside of the front passenger wheel. It seems to be coming from where the free hub bolts to the standard hub. No oil on inside of wheel or hub. It only leaks when it is driven. Could this be caused by the axle seal or something less of a concern. Any thoughts/advice appreciated.
31st October 2021 03:34 PM
31st October 2021, 10:47 PM
Does it pong like diff or gearbox oil? It is fairly easy to whip off the free wheel hub and check it out. If it turns out its just grease, clean up the surfaces and apply a very fine bit of silicon to act as a seal when you replace the hub. Just make sure no sealant gets into the hub.
The Following 2 Users Say Thank You to mudnut For This Useful Post:
growler2058 (1st November 2021), MB (1st November 2021)
1st November 2021, 10:32 PM
2nd November 2021, 04:04 PM
This doesn't show much as I have wiped the oil/grease off the wheel. It only comes out in a couple of spots.
2nd November 2021, 06:59 PM
I think if old grease or oil is coming out, then water and muck can get in.
