22nd October 2021, 07:13 PM
Horn, Cruise Control not working, Airbag light Flashing???
Hey,
2003 TD42 wagon, manual.
Come home from 4wding, airbag light started flashing during the drive, then the horn and cruise control have stopped working.
Are these connected?
Any help appreciated, have checked fuses and relays, all appears ok.
Couldn't find another recent thread on similar issues.
Thanks in advance
22nd October 2021 07:13 PM
23rd October 2021, 09:05 AM
Sounds like all the functions on the steering wheel have ceased to function. I would start looking at the connector for the wheel assembly
Greg Pointing
Conservation, Rehabilitation & Education
1989 GQ Patrol Wagon, TB42 Auto - Now with 2" of added lift...
1991 Mazda MX5 - Coilovers, Exhaust, Intake, NB brakes & seats.
2012 Mitsubishi Triton 4x4 Dual cab TDI - The Mrs truck....
23rd October 2021, 05:23 PM
All of the above run through your clock spring, either snapped the ribbon cable inside or the plug fell off the back
The Following User Says Thank You to johno90 For This Useful Post:
Mickhead (24th February 2022)
30th December 2021, 12:44 PM
Check all the wires under both front seats
24th February 2022, 04:04 PM
For the Cruise control , you haven't changed the brake globes to Led ones as I did and my Cruise wasn't working. the guys here told me to put back the old ones and all is working.
Airbag flashing come's on when in 4X4 drive I believe on the GU Ti model 97
