Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Radiator fan not working properly.
    80 Post(s)
    The ZD hubs are sealed. Only the TD hubs can be re-oiled.
    As for the OP. Check both radiator and condenser to see if they are blocked or not. Air flow is key, especially at low speeds.
    Thanks, mate. Good to learn something new. What a bastard having it sealed. I wonder if drilling a set of holes, draining the oil, and fitting bolts through the hub is a possible Quick Fix?
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    There is a fix for this, rebuilding the hub, using a silicon oil from Toyota. I have tried searching for a thread that deals with it. Hopefully someone sees this thread and can point you in the right direction.
    I just happened to be lookin at it on patrolapart ...
    https://patrolapart.com.au/product/t...n-patrol-gq-gu
    Edit: just read the post above. I've drilled holes in things to drain/replace fluid before (on motorbikes).
    2008 CRD Auto Wagon
  4. #13
    Sep 2015
    The AC system has a pressure switch that safeguards against too low/too high pressure. It cuts the AC before damage can be done.
    Has your dashboard been completely removed to replace the "smashed evaporator"?
    I don't know if the dashboard was removed I left it one day, picked up the next. The AC guy didn't mention the pressure switch, just told me that the pressure "smashed" the evaporator and will continue to "smash" other AC components until fixed.
    I did find a clip on Youtube how to easily check a viscous fan. Take 4-5 pages from a newspaper, roll them up and try to stop the fan with the roll just after you've started the car. The fan should be easy to stop. Then idle until the engine has reached max temp. When trying to stop the fan now, the newspaper should be ripped to shreds and the fan impossible to stop. This didn't happen to me.... the oil has obviously leaked out.
    I did find some oil on a plug below the water pump, see attached pic. Could it have anything to do with the fan oil or totally unrelated?
    Thanks everyone who replied.
    Pete
  5. #14
    Quote Originally Posted by pete57 View Post
    Pete
    Drive the car to get it to temp. Fluctuating revs will assist it reaching the desired temp and with oil flow through the vanes of the hub.
  6. #15
    Sep 2015
    Yes, did so and still fan is still not working properly. Definitely bad.
    Any idea from the pic what that oil leak might be? (what is that plug between the crankshaft and the compressor?)
  7. #16
    Yeah not sure what that is, not even the parts catalogue tells me. It does look like its leaking from that plug though. Maybe clean it up and monitor it??
