12th October 2021, 11:15 AM
Where do the breather tubes end on my 1999 4.5 Pattrol (stock)
Hi all, I'm Julian G and new to the forum. I have diff oil leaking from the front axle housing. I've replaced the oil/grease seal and guard one month ago. The leak reappeared again recently. Any suggestions for the fix would be greatly appreciated. Could it be a clogged breather valve? Thanks in advance.
12th October 2021 11:15 AM
12th October 2021, 12:07 PM
Not sure about the 1999 as I understand that is a Y61, but on my Y60, front diff, manual transmission and transfer case breathers all join close to the firewall and a steel tube goes up to the higher side of the inner fender into a rubber grommet. It basically ventilates on the same place where the original airbox/cyclone breathes air in.
Rear diff goes somewhere on the rear end of the car, I have forgoten now where it goes...
12th October 2021, 08:19 PM
Welcome to the forum mate.
12th October 2021, 08:34 PM
Travelling Podologist
Yep mine used to terminate inside the passenger side front mudguard diffs. IIRC both front & rear. I extended mine to under the bonnet at the bottom of the windscreen.
12th October 2021, 09:43 PM
Hardcore
The rear one goes into a rear chassis cross rail tube, the ends are normally blocked off with vented plastic end caps.
