10th October 2021, 09:52 PM
Expert Dingbat
Engine oil leaking from intake manifold
Hey peeps...just got back from a run down the Blackwood to Fitzgerald River National Park and the old TD42 NA started to drone in waves on the way back.
Got home fine but started the rig in the morning and it idled at 700 so I adjusted it.
Noticed black oil seeping g from the join at the front of the intake manifold and the recently replace main seal was leaking again...
Anyone seen anything like this?
After driving to.work n back the rig was now idling at 1000 so I wound the idle down again. It now runs with a wavy droning....just started doing it.
Never been thrashed over 3k n serviced every 5000kms.
Just asking around...
Quad-Drive 4WD Club...Western Australia
We're all here coz we ain't all there...
10th October 2021 09:52 PM
11th October 2021, 08:16 AM
where does the engine breather come into the inlet system ?
does it have excessive crankcase pressure. I think it might be breathing a bit heavy its running on the fumes . disconnect the breather so as to minimise the risk of a run away . dont leave it ideling and walk away !!
The Following User Says Thank You to Tip12345 For This Useful Post:
mudnut (11th October 2021)
11th October 2021, 10:35 AM
Has it got a PCV valve? Had the same problem with my Falcon and found a mechanic hadn't connected it properly. It was sucking air instead of scavenging the blow by.
MB TD42 (12th October 2021)
12th October 2021, 12:07 AM
Expert Dingbat
mudnut
Will check under the filter box...Cheers
