Results 1 to 4 of 4
Thread: Engine oil leaking from intake manifold
    Expert Dingbat MB TD42's Avatar
    Jan 2018
    Perth WA
    Hey peeps...just got back from a run down the Blackwood to Fitzgerald River National Park and the old TD42 NA started to drone in waves on the way back.
    Got home fine but started the rig in the morning and it idled at 700 so I adjusted it.
    Noticed black oil seeping g from the join at the front of the intake manifold and the recently replace main seal was leaking again...
    Anyone seen anything like this?
    After driving to.work n back the rig was now idling at 1000 so I wound the idle down again. It now runs with a wavy droning....just started doing it.
    Never been thrashed over 3k n serviced every 5000kms.
    Just asking around...
    Quad-Drive 4WD Club...Western Australia
    We're all here coz we ain't all there...
    May 2016
    8 Post(s)
    where does the engine breather come into the inlet system ?
    does it have excessive crankcase pressure. I think it might be breathing a bit heavy its running on the fumes . disconnect the breather so as to minimise the risk of a run away . dont leave it ideling and walk away !!
  4. The Following User Says Thank You to Tip12345 For This Useful Post:
    mudnut (11th October 2021)
    Has it got a PCV valve? Had the same problem with my Falcon and found a mechanic hadn't connected it properly. It was sucking air instead of scavenging the blow by.
  6. The Following User Says Thank You to mudnut For This Useful Post:
    MB TD42 (12th October 2021)
  7. #4
    Jan 2018
    Perth WA
    Will check under the filter box...Cheers
