7th August 2011, 09:58 PM
Hi YNOT, You think that somthing could be blocked to stop my boost from going higher.
7th August 2011 09:58 PM
7th August 2011, 10:03 PM
Hi YNOT, You think that somthing could be blocked.
7th August 2011, 10:10 PM
From what you have written earlier you had full power before the rebuild but without a boost gauge can only assume you were getting full boost from the old turbo, so the problem has only occured post rebuild.
First you need to establish that the fuel system is working correctly, if the ECU is limiting fuel for some reason there will not be enough heat in the exhaust to spin the turbo up to full boost. This is where a pyro gauge is useful. If boost and EGT's are down then there would seem to be a fueling issue, if boost is down and EGT's are up then fueling is OK and it would indicate a turbo issue. It's possible the boost limiting grub screw on the turbo is out of adjustment.
Have you done a code test yet?
Tony
7th August 2011, 10:22 PM
Ye mate done a code test and every thing is good, we did have a bit of play with the wastgate adjustment and only did a bit of diferance witch I thought it would as I'd say the ecu has taken over.
7th August 2011, 10:38 PM
If the turbo you fitted has a wastegate then it's the wrong turbo, Patrol ZD30 has variable nozzle instead of a wastegate.
Your turbo should look like this;
Tony
7th August 2011, 10:46 PM
Sorry mate mighten be a wast gate then. It's the vacume rod between the intake and exust of the turbo. SORRY I hope this helps. but it is the same as the one that came out except this one isn't water cooled.
7th August 2011, 10:53 PM
#17
All good mate.
Top right of this image it shows a grub screw. The text below it says to wind it down but you would want to go the other way to try to get more boost.
Tony
7th August 2011, 10:54 PM
#18
Yep Tony got your pic thats it and thats what we had a play with. That adjusment in your pic.
7th August 2011, 11:02 PM
#19
Ok I'm with you now. we adjusted the actuator rod.[I did'nt see that grub screw] I will try that grub screw tomorow if I got time and I will let you know how I went. Tony thanks a heap and will get back to you. ok must go to bed as I have a 5am start. thanks mate.
10th August 2011, 08:25 PM
#20
Hi Tony, I have adjusted that grub screw today and it made a bit of diferance but not that much.It seems to pull ok in 1st 2nd and 3rd but lags in 4th and 5th. I'll take it for a run on the week end and see if there is any differance. Other than that I'll look at puting it on a dyno. or just burn it.haha
