Hey guys this could be a mouthful but here goes.
Due to some melting and a little rushed wiring I've changed out the VL loom in my gq for an R31 loom. Heres where it gets annoying... I have it wired up with the typical pinout for this loom and no good news followed, I've run constant and 12V ignition still no go, she's fully earthed, still no go, I can get her to turn over but she won't fire, I spray some degreaser down the throttle and she wants to fire so I know I have spark, my issue is I don't hear my injectors pulse, I can loop the injector wiring at the ecu plug end and hear them pulse but I can't leave it in such a way. My earths are heating when I try and start and my positive terminal was hot as hell so I know theres a problem.
I've joined the usual pins but nothing, I thought maybe my ignition isn't giving enough constant so I switched the wire to battery, nothing. The 3 pin plug I'm not sure is even doing anything, I can bridge pin 6 to anything I like key on or off and hear the green eccs relay ping off its rocker. If someone has direct pictures of the R31 wired in to and from locations on an rb30et gq that would be great so I can double check every last tiny connection against the images shared.
I followed everything for it and the result is disappointing, I've read every forum post available and still no result produced, Pictures are worth a thousand words if someone can help I'd appriciate it.
